PCP implementation
Till Straumann strauman at slac.stanford.edu
Tue Mar 21 22:22:02 UTC 2006
I agree and I consider this a major design flaw.
Indeed: by looking at the source code and testing
your example I can confirm the documented
behavior.
Note that priority-inheriting binary semaphores
exhibit the same flaw.
When surrendering a priority-ceiling or -inheriting
mutex the executing task priority should be changed
to the highest priority (ceiling or inherited) of all currently
held mutexes.
-- Till
Martin Molnar wrote:
> Hi,
> Could anybody explain me how exactly Priority Ceiling Protocol (PCP)
> is implemented in RTEMS? I think it works differently than PCP
> described in technical books.
> Example:
> 1.Task1 (current priority 10) obtains the mutex SEM1 and its priority
> is raised to the mutex ceiling (9).
> 2.Task1 ( current priority 9) obtains the mutex SEM2 and its priority
> is raised to the mutex ceiling (5).
> 3.Task1 ( current priority 5) releases the mutex SEM2. I would expect
> the priority to be changed to value 9. However, the priority remains
> unchanged. From RTEMS documentation: Only when the task releases ALL
> of the binary semaphores it holds will its priority be restored to the
> normal value.
> I am not sure, whether RTEMS PCP(and also Priority Inheritance
> Protocol) is correct. Because,now Task1 can block for example TAsk2
> with priority 6.
> Thanks for explanation
>  Martin Molnar
