4.6 Barrier Patch for Review
    Pavel Pisa
    ppisa4lists at pikron.com
    Wed Mar  1 22:40:59 UTC 2006
On Wednesday 01 March 2006 23:08, Joel Sherrill wrote:
>  #define _ISR_Enable( _level ) \
> -        _CPU_ISR_Enable( _level )
> +  do { \
> +    _CPU_ISR_Enable( _level ); \
> +    RTEMS_COMPILER_MEMORY_BARRIER(); \
> +  } while (0)
Hello Joel,
I think, that barrier and enable order has to
follow original Till Straumann's ordering,
else there is allmost neglectable but real chance,
that GCC moves something from protected region
before _ISR_Enable() after interrupt enable
instruction, because barrier is in the fact
after it and blocking only move of the code
after whole _ISR_Enable() construct.
do { \
 } while (0)
Same for _ISR_Flash()
#define _ISR_Flash( _level ) \
  do { \
    _CPU_ISR_Flash( _level ); \
  } while(0)
Again fault is non-probable but possible in theoretically constructed case.
The two subsequent "calls" to RTEMS_COMPILER_MEMORY_BARRIER()
has zero cost in reality, because the first one already forces
moves of all data and they do not represent any instruction.
Best wishes
                Pavel Pisa
