What's wrong in this simple posix example ?
Matteo
matteo.posterli at studenti.unipr.it
Thu Mar 2 09:17:17 UTC 2006
Thanks for the suggestion but the system still crash, the problem is the the
task with lowest priority is never launched, but I don't know why!
Someone have some idea ?
Thanks in advance
Matteo
Scrive Sergei Ablalimov <sa at design.morion.ru>:
> Hello Matteo,
> I run your sample and see:
> <main> Enter in the main
> Creating first task
> <child>: Hello World! task with max priority
> First Task created
> The task is coming to enter in a timed wait
> Creating second task
> Second task created
> <main> Out of the main
> The task is coming out from the timed wait
> After that - crash.
> using rtems_task_delete(RTEMS_SELF) instead of exit resolve problem.
> Thursday, March 2, 2006, 4:53:11 AM, you wrote:
> > Hi
> > I'm working with posix thread and I'm trying to launch 2 thread with
> different
> > priority but I have a lot of error of memory but I'm using a really simple
> > example of one threads that uses a timed wait and onother one that is
> simple
> > launched.
> > The code is just below ;
> > #include <sched.h>
> > #include <bsp.h>
> > #include <stdlib.h>
> > #include <stdio.h>
> > #include <pthread.h>
> > pthread_mutex_t mutex;
> > pthread_cond_t cond;
> > struct timespec timeout;
> > struct sched_param param;
> > pthread_attr_t attr;
> > void * print_hello(void * arg){
> > printf("<child>: Hello World! task with max priority \n");
> > clock_gettime( CLOCK_REALTIME, &timeout );
> > timeout.tv_sec += 3;
> > timeout.tv_nsec = 0;
> > printf("The task is coming to enter in a timed wait\n");
> > pthread_cond_timedwait(&cond, &mutex, &timeout);
> > printf("The task is coming out from the timed wait \n");
> > return NULL;
> > void * print_hello_a(void * arg){
> > printf(" <child>: Hello World! Task with lowest priority ");
> > return NULL;
> > void *POSIX_Init()
> > pthread_t child1;
> > pthread_t child2;
> > pthread_attr_init(&attr);
> > pthread_attr_setschedpolicy(&attr, SCHED_FIFO);
> > pthread_mutex_init( &mutex, NULL );
> > pthread_cond_init( &cond, NULL );
> > printf("<main> Enter in the main \n");
> > printf("Creating first task \n");
> > param.sched_priority = sched_get_priority_max(SCHED_FIFO);
> > pthread_attr_setschedparam(&attr, ¶m);
> > if ( pthread_create( &child1, &attr, print_hello, NULL) ||
> > pthread_setschedparam(child1, SCHED_FIFO, ¶m) ) {
> > printf("Thread cannot be created or you have not enough privileges to
> set
> > priority!!!!\n");
> > exit(1);
> > printf("First Task created \n");
> > printf("Creating second task \n");
> > param.sched_priority = sched_get_priority_max(SCHED_FIFO) - 1;
> > if ( pthread_create( &child2, &attr, print_hello_a, NULL) ||
> > pthread_setschedparam(child2, SCHED_FIFO, ¶m) ) {
> to
> > set priority!!!!\n");
> > exit(1);
> > printf("Second task created \n");
> > printf("<main> Out of the main\n");
> > pthread_join( child1, NULL );
> > pthread_join( child2, NULL );
> > exit(0);
> > #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_TEST_NEEDS_TIMER_DRIVER
> > #define CONFIGURE_MAXIMUM_POSIX_THREADS 10
> > #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES 10
> > #define CONFIGURE_MAXIMUM_POSIX_MUTEXES 10
> > #define CONFIGURE_POSIX_INIT_THREAD_TABLE
> > #define CONFIGURE_INIT
> > #include <rtems/confdefs.h>
> > What's wrong?
> > I don't understand what could be the problem!
> > Someone can help me ?
> > Really thanks in advance
> > Matteo
> Best regards,
> Sergei
