Problem when compiling gcc for rtems-4.6 toolchain
    Dominik Brader
    dbrader at gmx.net
    Thu Mar  2 21:49:59 UTC 2006
Hi Joel,
yes I included the gcc-3.3.5 in the path and made sure that I use it.
Dominik
On Thursday 02 March 2006 21:26, you wrote:
> Dominik Brader wrote:
> >Hello Angelo,
> >thank you for your reply...
> >I tried your suggestions but it still didn't work.
> >The error is still the same...
> Did you install the old native gcc and put it at the front of your PATH?
> echo $PATH
> gcc --version
> and make sure.
> --joel
> >Dominik
> >>>On Tuesday 28 February 2006 21:59, you wrote:
> >>>>Dominik Brader wrote on 2/28/06 12:45 PM:
> >>>>>Hello,
> >>>>>I have a problem when compiling the gcc for the RTEMS-4.6. toolchain.
> >>>>>I am using binutils-2.13.2.1, gcc-3.2.3 with
> >>>>>gcc-3.2.3-rtems-20040420.diff patch and newlib-1.11.0 with
> >>>>>newlib-1.11.0-rtems-20030605.diff patch.
> >>I had a very similar problem the other day.
> >>I found that I had to use gcc 3.3.5 to make it work for rtems 4.6.4
> >>I have the whole procedure at
> >>http://www.smartcontroller.com.au/~angelo/rtems/RTEMSForSmartController.h
> >>tm l
> >>Let me know if it helps
Dominik Brader - Friedenheimerstr. 16 - 80687 München
