4.6 Barrier Patch for Review
    Bill Knight
    BillK at rosw.com
    Fri Mar  3 14:03:24 UTC 2006
Why not be safe and but it before and after.  It doesn't actually
take any code space, it simply tells the optimizer not to move
code across it.
Regards
-Bill Knight
R O SoftWare
On Fri, 03 Mar 2006 09:39:06 +0800, Ian Caddy wrote:
>Hi,
>I thought we had also agree to put the barrier *before* the disable_isr,
>this is the same as Thomas's request for moving the barrier to *before*
>the _Thread_Unnest_dispatch.
>regards,
>Ian Caddy
>Joel Sherrill wrote:
>> Thomas Doerfler wrote:
>>> Joel,
>>> nearly, but no. (sorry).
>> That's what the review request was for. :)
>>> I think the _Thread_Unnest_dispatch function still does it the wrong
>>> way round:
>> This should be fixed along with Eric Norum's suggestion about not
>> needing the
>> do/while in the BARRIER macro.
>> Did Mattias and Elena get to play in the snow this week?  We peeked in
>> on the webcam in Marienplatz and it looked quite snowy a few days ago.
>> --joel
>> Index: cpukit/score/include/rtems/system.h
>> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/system.h,v
>> retrieving revision 1.32.2.5
>> diff -u -r1.32.2.5 system.h
>> --- cpukit/score/include/rtems/system.h	14 Jan 2005 05:23:21 -0000	1.32.2.5
>> +++ cpukit/score/include/rtems/system.h	2 Mar 2006 16:21:30 -0000
>> @@ -102,6 +102,17 @@
>>  #endif
>> + *  The following macro is a compiler specific way to ensure that memory
>> + *  writes are not reordered around certian points.  This specifically can
>> + *  impact interrupt disable and thread dispatching critical sections.
>> +#ifdef __GNUC__
>> +  #define RTEMS_COMPILER_MEMORY_BARRIER() asm volatile("" ::: "memory")
>> +#else
>> +#endif
>>   *  The following are used by the POSIX implementation to catch bad paths.
>> Index: cpukit/score/include/rtems/score/isr.h
>> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/score/isr.h,v
>> retrieving revision 1.17.2.1
>> diff -u -r1.17.2.1 isr.h
>> --- cpukit/score/include/rtems/score/isr.h	4 Sep 2003 18:55:05 -0000	1.17.2.1
>> +++ cpukit/score/include/rtems/score/isr.h	2 Mar 2006 16:21:30 -0000
>> @@ -111,7 +111,10 @@
>>  #define _ISR_Disable( _level ) \
>> -        _CPU_ISR_Disable( _level )
>> +  do { \
>> +    _CPU_ISR_Disable( _level ); \
>> +    RTEMS_COMPILER_MEMORY_BARRIER(); \
>> +  } while (0)
>>   *  _ISR_Enable
>> @@ -124,7 +127,10 @@
>>  #define _ISR_Enable( _level ) \
>> -        _CPU_ISR_Enable( _level )
>> +  do { \
>> +    _CPU_ISR_Enable( _level ); \
>> +  } while (0)
>>   *  _ISR_Flash
>> @@ -144,7 +150,11 @@
>>  #define _ISR_Flash( _level ) \
>> -        _CPU_ISR_Flash( _level )
>> +  do { \
>> +    _CPU_ISR_Flash( _level ); \
>> +  } while (0)
>>   *  _ISR_Install_vector
>> Index: cpukit/score/inline/rtems/score/thread.inl
>> RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/thread.inl,v
>> retrieving revision 1.17.2.2
>> diff -u -r1.17.2.2 thread.inl
>> --- cpukit/score/inline/rtems/score/thread.inl	15 Sep 2003 02:12:47 -0000	1.17.2.2
>> +++ cpukit/score/inline/rtems/score/thread.inl	2 Mar 2006 16:21:30 -0000
>> @@ -184,6 +184,7 @@
>>  RTEMS_INLINE_ROUTINE void _Thread_Disable_dispatch( void )
>>    _Thread_Dispatch_disable_level += 1;
>>  /*PAGE
>> @@ -201,6 +202,7 @@
>>  #if ( CPU_INLINE_ENABLE_DISPATCH == TRUE )
>>  RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch()
>>    if ( (--_Thread_Dispatch_disable_level) == 0 )
>>      _Thread_Dispatch();
>> @@ -223,6 +225,7 @@
>>  RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
>>    _Thread_Dispatch_disable_level -= 1;
>> Index: cpukit/score/macros/rtems/score/thread.inl
>> RCS file: /usr1/CVS/rtems/cpukit/score/macros/rtems/score/thread.inl,v
>> retrieving revision 1.12.2.1
>> diff -u -r1.12.2.1 thread.inl
>> --- cpukit/score/macros/rtems/score/thread.inl	4 Sep 2003 18:55:06 -0000	1.12.2.1
>> +++ cpukit/score/macros/rtems/score/thread.inl	2 Mar 2006 16:21:30 -0000
>> @@ -126,7 +126,10 @@
>>  #define _Thread_Disable_dispatch() \
>> -  _Thread_Dispatch_disable_level += 1
>> +  do { \
>> +    _Thread_Dispatch_disable_level += 1; \
>> +  } while (0)
>>  /*PAGE
>> @@ -136,9 +139,11 @@
>>  #define _Thread_Enable_dispatch()  \
>> -      { if ( (--_Thread_Dispatch_disable_level) == 0 ) \
>> -             _Thread_Dispatch();  \
>> +  do { \
>> +    if ( (--_Thread_Dispatch_disable_level) == 0 ) \
>> +       _Thread_Dispatch(); \
>> +  } while (0)
>>  #endif
>>  #if ( CPU_INLINE_ENABLE_DISPATCH == FALSE )
>> @@ -152,7 +157,10 @@
>>  #define _Thread_Unnest_dispatch()  \
>> -  _Thread_Dispatch_disable_level -= 1
>> +  do { \
>> +    _Thread_Dispatch_disable_level -= 1; \
>> +  } while (0)
>>  /*PAGE
>Ian Caddy
>Goanna Technologies Pty Ltd
>+61 8 9221 1860
