Was last Barrier Patch OK?
Thomas Doerfler
Thomas.Doerfler at imd-systems.de
Tue Mar 7 13:57:33 UTC 2006
Joel,
how often will I look at the patch and find bugs again, sigh!
In the macro _Thread_Disable_dispatch(), the memory barrier seems to be
misplaced.
I have corrected it (hopefully) and nothing else in the attached patch.
So the temperature in Alabama is almost similar to munich, it seems. we
got half a meter of snow this weekend, this is the absolute record at
least for a century. And it just starts snowing again =8>
wkr,
Thomas.
Joel Sherrill wrote:
> Thomas Doerfler (nt) wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Till,
>> ups, you got it, I actually missed that one when I checked the patch.
>> Joel, can you fix it (AFTER! the camping trip with your boys)?
>> wkr,
>> Thomas.
>> Till Straumann schrieb:
>>> Sorry, NO, it's still *not* OK.
>>> - the '.inl' version of _Thread_Unnest_dispatch()
>>> has the barrier after the decrement operation instead
>>> of before.
>>> Looks like you could use some vacation...
>>> -- T.
> Yeah and time to recover from it afterwards. :) We were near Auburn
> Alabama and it got down
> below freezing Friday night. The days were warm and sunny while the
> nights were cold. Combine
> that with the 4 hour drive there and I didn't get much sleep the first
> night. I will barely have time to
> catch up on my sleep before doing another trip to Montgomery this
> weekend. One of my sons is on
> the school Science Olympiad team which won the regional competition and
> is going to state!
> Anyway I think I have this all fixed in the attached patch.
> critical section enter
> barrier
> protected operation
> barrier
> critical section exit
> One other thought. Can gcc move the critical section enter earlier and
> exit later to include more
> in the critical section?
> --joel
> Index: cpukit/score/include/rtems/system.h
> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/system.h,v
> retrieving revision 1.32.2.5
> diff -u -r1.32.2.5 system.h
> --- cpukit/score/include/rtems/system.h 14 Jan 2005 05:23:21 -0000 1.32.2.5
> +++ cpukit/score/include/rtems/system.h 7 Mar 2006 12:14:04 -0000
> @@ -102,6 +102,17 @@
> #endif
> + * The following macro is a compiler specific way to ensure that memory
> + * writes are not reordered around certian points. This specifically can
> + * impact interrupt disable and thread dispatching critical sections.
> +#ifdef __GNUC__
> + #define RTEMS_COMPILER_MEMORY_BARRIER() asm volatile("" ::: "memory")
> +#else
> +#endif
> * The following are used by the POSIX implementation to catch bad paths.
> Index: cpukit/score/include/rtems/score/isr.h
> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/score/isr.h,v
> retrieving revision 1.17.2.1
> diff -u -r1.17.2.1 isr.h
> --- cpukit/score/include/rtems/score/isr.h 4 Sep 2003 18:55:05 -0000 1.17.2.1
> +++ cpukit/score/include/rtems/score/isr.h 7 Mar 2006 12:14:04 -0000
> @@ -111,7 +111,10 @@
> #define _ISR_Disable( _level ) \
> - _CPU_ISR_Disable( _level )
> + do { \
> + _CPU_ISR_Disable( _level ); \
> + RTEMS_COMPILER_MEMORY_BARRIER(); \
> + } while (0)
> * _ISR_Enable
> @@ -124,7 +127,10 @@
> #define _ISR_Enable( _level ) \
> - _CPU_ISR_Enable( _level )
> + do { \
> + _CPU_ISR_Enable( _level ); \
> + } while (0)
> * _ISR_Flash
> @@ -144,7 +150,11 @@
> #define _ISR_Flash( _level ) \
> - _CPU_ISR_Flash( _level )
> + do { \
> + _CPU_ISR_Flash( _level ); \
> + } while (0)
> * _ISR_Install_vector
> Index: cpukit/score/inline/rtems/score/thread.inl
> RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/thread.inl,v
> retrieving revision 1.17.2.2
> diff -u -r1.17.2.2 thread.inl
> --- cpukit/score/inline/rtems/score/thread.inl 15 Sep 2003 02:12:47 -0000 1.17.2.2
> +++ cpukit/score/inline/rtems/score/thread.inl 7 Mar 2006 12:14:04 -0000
> @@ -184,6 +184,7 @@
> RTEMS_INLINE_ROUTINE void _Thread_Disable_dispatch( void )
> _Thread_Dispatch_disable_level += 1;
> /*PAGE
> @@ -201,6 +202,7 @@
> #if ( CPU_INLINE_ENABLE_DISPATCH == TRUE )
> RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch()
> if ( (--_Thread_Dispatch_disable_level) == 0 )
> _Thread_Dispatch();
> @@ -223,6 +225,7 @@
> RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
> _Thread_Dispatch_disable_level -= 1;
> Index: cpukit/score/macros/rtems/score/thread.inl
> RCS file: /usr1/CVS/rtems/cpukit/score/macros/rtems/score/thread.inl,v
> retrieving revision 1.12.2.1
> diff -u -r1.12.2.1 thread.inl
> --- cpukit/score/macros/rtems/score/thread.inl 4 Sep 2003 18:55:06 -0000 1.12.2.1
> +++ cpukit/score/macros/rtems/score/thread.inl 7 Mar 2006 12:14:04 -0000
> @@ -126,7 +126,10 @@
> #define _Thread_Disable_dispatch() \
> - _Thread_Dispatch_disable_level += 1
> + do { \
> + _Thread_Dispatch_disable_level += 1; \
> + } while (0)
> /*PAGE
> @@ -136,9 +139,11 @@
> #define _Thread_Enable_dispatch() \
> - { if ( (--_Thread_Dispatch_disable_level) == 0 ) \
> - _Thread_Dispatch(); \
> + do { \
> + if ( (--_Thread_Dispatch_disable_level) == 0 ) \
> + _Thread_Dispatch(); \
> + } while (0)
> #endif
> #if ( CPU_INLINE_ENABLE_DISPATCH == FALSE )
> @@ -152,7 +157,10 @@
> #define _Thread_Unnest_dispatch() \
> - _Thread_Dispatch_disable_level -= 1
> + do { \
> + _Thread_Dispatch_disable_level -= 1; \
> + } while (0)
> /*PAGE
IMD Ingenieurbuero fuer Microcomputertechnik
Thomas Doerfler Herbststrasse 8
D-82178 Puchheim Germany
email: Thomas.Doerfler at imd-systems.de
PGP public key available at:
http://www.imd-systems.de/pgpkey_en.html
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20060307/39b42531/attachment-0001.ksh>
