Was last Barrier Patch OK?
    Till Straumann
    strauman at slac.stanford.edu
    Tue Mar  7 21:23:02 UTC 2006
Till Straumann wrote:
> Thomas Doerfler wrote:
>> Joel,
>> how often will I look at the patch and find bugs again, sigh!
> Darn! Had missed that one,too. How long will it take 4 people to
> get this right???!!! It's a *#@$ JOKE
No - I hadn't missed it. This was a newly introduced one.
Joel, I guess you have to come up with a new 'final' version
and we'll have to double-check everything again...
reminder - it needs to be
     apply protection
     BARRIER
       critical section
     BARRIER
     remove protection
sigh.
T.
> T.
>> In the macro _Thread_Disable_dispatch(), the memory barrier seems to
>> be misplaced.
>> I have corrected it (hopefully) and nothing else in the attached patch.
>> So the temperature in Alabama is almost similar to munich, it seems.
>> we got half a meter of snow this weekend, this is the absolute record
>> at least for a century. And it just starts snowing again =8>
>> wkr,
>> Thomas.
>> Joel Sherrill wrote:
>>> Thomas Doerfler (nt) wrote:
>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>> Hash: SHA1
>>>> Till,
>>>> ups, you got it, I actually missed that one when I checked the patch.
>>>> Joel, can you fix it (AFTER! the camping trip with your boys)?
>>>> wkr,
>>>> Thomas.
>>>> Till Straumann schrieb:
>>>>> Sorry, NO, it's still *not* OK.
>>>>> - the '.inl' version of _Thread_Unnest_dispatch()
>>>>>  has the barrier after the decrement operation instead
>>>>>  of before.
>>>>> Looks like you could use some vacation...
>>>>> -- T.
>>> Yeah and time to recover from it afterwards. :)  We were near Auburn
>>> Alabama and it got down
>>> below freezing Friday night.  The days were warm and sunny while the
>>> nights were cold.  Combine
>>> that with the 4 hour drive there and I didn't get much sleep the
>>> first night.  I will barely have time to
>>> catch up on my sleep before doing another trip to Montgomery this
>>> weekend.  One of my sons is on
>>> the school Science Olympiad team which won the regional competition
>>> and is going to state!
>>> Anyway I think I have this all fixed in the attached patch.
>>>  critical section enter
>>>  barrier
>>>    protected operation
>>>  barrier
>>>  critical section exit
>>> One other thought.  Can gcc move the critical section enter earlier
>>> and exit later to include more
>>> in the critical section?
>>> --joel
>>> Index: cpukit/score/include/rtems/system.h
>>> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/system.h,v
>>> retrieving revision 1.32.2.5
>>> diff -u -r1.32.2.5 system.h
>>> --- cpukit/score/include/rtems/system.h    14 Jan 2005 05:23:21
>>> -0000    1.32.2.5
>>> +++ cpukit/score/include/rtems/system.h    7 Mar 2006 12:14:04 -0000
>>> @@ -102,6 +102,17 @@
>>>  #endif
>>> + *  The following macro is a compiler specific way to ensure that
>>> memory
>>> + *  writes are not reordered around certian points.  This
>>> specifically can
>>> + *  impact interrupt disable and thread dispatching critical sections.
>>> +#ifdef __GNUC__
>>> +  #define RTEMS_COMPILER_MEMORY_BARRIER() asm volatile("" ::: "memory")
>>> +#else
>>> +#endif
>>>   *  The following are used by the POSIX implementation to catch bad
>>> paths.
>>> Index: cpukit/score/include/rtems/score/isr.h
>>> RCS file: /usr1/CVS/rtems/cpukit/score/include/rtems/score/isr.h,v
>>> retrieving revision 1.17.2.1
>>> diff -u -r1.17.2.1 isr.h
>>> --- cpukit/score/include/rtems/score/isr.h    4 Sep 2003 18:55:05
>>> -0000    1.17.2.1
>>> +++ cpukit/score/include/rtems/score/isr.h    7 Mar 2006 12:14:04 -0000
>>> @@ -111,7 +111,10 @@
>>>  #define _ISR_Disable( _level ) \
>>> -        _CPU_ISR_Disable( _level )
>>> +  do { \
>>> +    _CPU_ISR_Disable( _level ); \
>>> +    RTEMS_COMPILER_MEMORY_BARRIER(); \
>>> +  } while (0)
>>>   *  _ISR_Enable
>>> @@ -124,7 +127,10 @@
>>>  #define _ISR_Enable( _level ) \
>>> -        _CPU_ISR_Enable( _level )
>>> +  do { \
>>> +    _CPU_ISR_Enable( _level ); \
>>> +  } while (0)
>>>   *  _ISR_Flash
>>> @@ -144,7 +150,11 @@
>>>  #define _ISR_Flash( _level ) \
>>> -        _CPU_ISR_Flash( _level )
>>> +  do { \
>>> +    _CPU_ISR_Flash( _level ); \
>>> +  } while (0)
>>>   *  _ISR_Install_vector
>>> Index: cpukit/score/inline/rtems/score/thread.inl
>>> RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/thread.inl,v
>>> retrieving revision 1.17.2.2
>>> diff -u -r1.17.2.2 thread.inl
>>> --- cpukit/score/inline/rtems/score/thread.inl    15 Sep 2003
>>> 02:12:47 -0000    1.17.2.2
>>> +++ cpukit/score/inline/rtems/score/thread.inl    7 Mar 2006 12:14:04
>>> -0000
>>> @@ -184,6 +184,7 @@
>>>  RTEMS_INLINE_ROUTINE void _Thread_Disable_dispatch( void )
>>>    _Thread_Dispatch_disable_level += 1;
>>>  /*PAGE
>>> @@ -201,6 +202,7 @@
>>>  #if ( CPU_INLINE_ENABLE_DISPATCH == TRUE )
>>>  RTEMS_INLINE_ROUTINE void _Thread_Enable_dispatch()
>>>    if ( (--_Thread_Dispatch_disable_level) == 0 )
>>>      _Thread_Dispatch();
>>> @@ -223,6 +225,7 @@
>>>  RTEMS_INLINE_ROUTINE void _Thread_Unnest_dispatch( void )
>>>    _Thread_Dispatch_disable_level -= 1;
>>> Index: cpukit/score/macros/rtems/score/thread.inl
>>> RCS file: /usr1/CVS/rtems/cpukit/score/macros/rtems/score/thread.inl,v
>>> retrieving revision 1.12.2.1
>>> diff -u -r1.12.2.1 thread.inl
>>> --- cpukit/score/macros/rtems/score/thread.inl    4 Sep 2003 18:55:06
>>> -0000    1.12.2.1
>>> +++ cpukit/score/macros/rtems/score/thread.inl    7 Mar 2006 12:14:04
>>> -0000
>>> @@ -126,7 +126,10 @@
>>>  #define _Thread_Disable_dispatch() \
>>> -  _Thread_Dispatch_disable_level += 1
>>> +  do { \
>>> +    _Thread_Dispatch_disable_level += 1; \
>>> +  } while (0)
>>>  /*PAGE
>>> @@ -136,9 +139,11 @@
>>>  #define _Thread_Enable_dispatch()  \
>>> -      { if ( (--_Thread_Dispatch_disable_level) == 0 ) \
>>> -             _Thread_Dispatch();  \
>>> +  do { \
>>> +    if ( (--_Thread_Dispatch_disable_level) == 0 ) \
>>> +       _Thread_Dispatch(); \
>>> +  } while (0)
>>>  #endif
>>>  #if ( CPU_INLINE_ENABLE_DISPATCH == FALSE )
>>> @@ -152,7 +157,10 @@
>>>  #define _Thread_Unnest_dispatch()  \
>>> -  _Thread_Dispatch_disable_level -= 1
>>> +  do { \
>>> +    _Thread_Dispatch_disable_level -= 1; \
>>> +  } while (0)
>>>  /*PAGE
>> -0000    1.32.2.5
>>  #endif
>> + *  The following macro is a compiler specific way to ensure that memory
>> specifically can
>> +#ifdef __GNUC__
>> +#else
>> +#endif
>> paths.
>> -0000    1.17.2.1
>> +  do { \
>> +  } while (0)
>>   *  _ISR_Enable
>> +  do { \
>> +  } while (0)
>>   *  _ISR_Flash
>> +  do { \
>> +  } while (0)
>> --- cpukit/score/inline/rtems/score/thread.inl    15 Sep 2003 02:12:47
>> -0000    1.17.2.2
>> -0000
>> @@ -184,6 +184,7 @@
>>  /*PAGE
>> @@ -201,6 +202,7 @@
>>      _Thread_Dispatch();
>> @@ -223,6 +225,7 @@
>> -0000    1.12.2.1
>> -0000
>> +  do { \
>> +  } while (0)
>>  /*PAGE
>> +  do { \
>> +  } while (0)
>>  #endif
>> +  do { \
>> +  } while (0)
>>  /*PAGE
