SV: RTEMS 4.6.4 fails on Cygwin
    Ole Hansen
    Ole at danelec.dk
    Mon Mar 13 21:27:47 UTC 2006
Hello Joe
Are there any preferences of version of GCC + tools to use for building crossgcc  ??
I have been building the crossGCC with help from Lars Munch, but we don't see a solution to the problem.
Will any of the prebuilt tools on rtems - homepage work better ??
  best regards
  ole at danelec.dk
 * Software Manager
  * danelec electronics a/s
  * Blokken 44
  * DK-3460 Birkeroed
  * DENMARK
   * Phone: +45 45821879
    * Fax:  +45 45821979
     * Email: ole at danelec.dk
      * http://www.danelec.dk
       * ftp://ftp.danelec.dk
        * Radio call sign: oz1jru
 *    If you seek luck, luck will strike you ..... 8o)       *
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: 13. marts 2006 16:23
> To: Ole Hansen
> Cc: Ralf Corsepius; RTEMS Users
> Subject: Re: SV: RTEMS 4.6.4 fails on Cygwin
> Ole Hansen wrote:
> >Hello joe
> >Don't really know what to look for:
> I see that your PATH has at least one Windows specific
> directory with spaces
> in it.  That could be an issue.
> Also INCLUDE is set for Visual Studio and has spaces in it.
> It is generally a good idea in Cygwin to clean out those two
> environment
> variables
> so they are Windows clean.
> --joel
> >obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems
> >$ env
> >HOMEPATH=\Documents and Settings\obh
> >MANPATH=/usr/local/man:/usr/share/man:/usr/man::/usr/ssl/man
> >APPDATA=C:\Documents and Settings\obh\Application Data
> >HOSTNAME=olenb2
> >VS71COMNTOOLS=C:\Program Files\Microsoft Visual Studio .NET
> 2003\Common7\Tools\
> >TERM=cygwin
> >PROCESSOR_IDENTIFIER=x86 Family 6 Model 9 Stepping 5, GenuineIntel
> >WINDIR=C:\WINDOWS
> >RTEMS_MAKEFILE_PATH=/opt/rtems/i386-rtems/i386-rtems/pc386
> >TEXDOCVIEW_txt=cygstart %s
> >TEXDOCVIEW_dvi=cygstart %s
> >QTDIR=/usr/lib/qt3
> >OLDPWD=/cygdrive/c/CVSROOT/development/ioboards/rtems/build-p
> c386-i386-rtems
> >USERDOMAIN=OLENB2
> >OS=Windows_NT
> >ALLUSERSPROFILE=C:\Documents and Settings\All Users
> >USER=obh
> >TEMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
> >COMMONPROGRAMFILES=C:\Program Files\Common Files
> >LIB=
> >USERNAME=obh
> >TEXDOCVIEW_pdf=cygstart %s
> >PROCESSOR_LEVEL=6
> >PATH=/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/cygdrive/c/
> WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/Syste
> m32/Wbem:/cygdrive/c/MSSQL
> >7/BINN:/cygdrive/c/Program Files/ATI Technologies/ATI
> Control Panel:/cygdrive/c/Program
> Files/Hummingbird/Connectivity/9.00/Accessories/:/cygdrive/c/
> >Program Files/cvsnt:/cygdrive/c/Program Files/IDM Computer
> Solutions/UltraEdit-32:/cygdrive/c/Program Files/IDM Computer
> Solutions/UEStudio:/usr/bin:
> Solutions/UltraCompare:/usr/lib/lapack:/opt/rtems/i386-rtems-gcc/bin
> >FP_NO_HOST_CHECK=NO
> >SYSTEMDRIVE=C:
> >TEXDOCVIEW_html=cygstart %s
> >USERPROFILE=C:\Documents and Settings\obh
> >QMAKESPEC=/usr/lib/qt3/mkspecs/cygwin-g++
> >PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
> >LOGONSERVER=\\OLENB2
> >PROCESSOR_ARCHITECTURE=x86
> >!C:=C:\cygwin\bin
> >SHLVL=1
> >HOME=/home/obh
> >PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
> >HOMEDRIVE=C:
> >PROMPT=$P$G
> >COMSPEC=C:\WINDOWS\system32\cmd.exe
> >TMP=/cygdrive/c/DOCUME~1/obh/LOCALS~1/Temp
> >SYSTEMROOT=C:\WINDOWS
> >PRINTER=\\bfs01\infotec 4451 MF PCL
> >CVS_RSH=/bin/ssh
> >PROCESSOR_REVISION=0905
> >PKG_CONFIG_PATH=/usr/X11R6/lib/pkgconfig
> >TEXDOCVIEW_ps=cygstart %s
> >MAKE_MODE=unix
> >INFOPATH=/usr/local/info:/usr/share/info:/usr/info:
> >NUMBER_OF_PROCESSORS=1
> >INCLUDE=C:\Program Files\Microsoft Visual Studio .NET
> 2003\SDK\v1.1\include\
> >SESSIONNAME=Console
> >COMPUTERNAME=OLENB2
> >_=/usr/bin/env
> >best regards
> >  ole at danelec.dk
> > * Software Manager
> >  * Blokken 44
> >  * DK-3460 Birkeroed
> >  * DENMARK
> >    * Fax:  +45 45821979
> >>Sent: 13. marts 2006 16:15
> >>To: Ole Hansen
> >>Ole Hansen wrote:
> >>>Hello Ralf
> >>>unsetting LIB does not change anything
> >>When you do an env in Cygwin do you see any other environment
> >>variables that
> >>look potentially useful to the build procedure and point to Windows
> >>specific places?
> >>--joel
> >>>regards
> >>>ole at danelec.dk
> >>>>From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> >>>>Sent: 13. marts 2006 09:10
> >>>>To: RTEMS Users
> >>>>Subject: RE: SV: RTEMS 4.6.4 fails on Cygwin
> >>>>On Mon, 2006-03-13 at 08:59 +0100, Ole Hansen wrote:
> >>>>>Hello Ralf
> >>>>>$ echo $LIB
> >>>>>C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Lib\
> >>>>That's your problem.
> >>>>Unsetting LIB should help.
> >>>>Ralf
