SV: RTEMS 4.6.4 fails on Cygwin
Ole Hansen
Ole at danelec.dk
Tue Mar 14 07:00:13 UTC 2006
Hello Ralf
This is what is printed on the screen:
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for strerror... yes
checking for strtol... yes
checking for perl... /usr/bin/perl
checking for bash... /usr/bin/bash
configure: creating ./config.status
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating ampolish3
config.status: creating config.h
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' '--prefix=/opt/rtems/i386-rtems' '--host=i6
86-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--target=i386
-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu'
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.6.99.2
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking target system type... i386-pc-rtems
checking rtems target cpu... i386
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
configure: configuring in generic
configure: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/generic/configure' --prefix=/opt/rtems/i386-rtems '--
prefix=/opt/rtems/i386-rtems' '--host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-
posix' '--disable-tests' '--target=i386-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu'
'build_alias=i686-pc-cygwin' 'host_alias=i686-pc-cygwin' 'target_alias=i386-rtems' --cache-file=/dev/null --srcdir=/cygdrive/c/CVSROOT/development/i
.infig.status: error: cannot find input file: Makefile
configure: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/generic/configure' failed for generic
configure: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' failed for tools/cpu
obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems
$ ls
Here is my config.log:
obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems/build-pc386-i386-rtems
$ cat config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by rtems configure 4.6.99.2, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/configure --target=i386-rtems --enable-rtemsbsp=pc386 --prefix=/opt/rtems/i386-rtems --d
isable-cxx --disable-itron --enable-posix --disable-tests
## Platform. ##
hostname = olenb2
uname -m = i686
uname -r = 1.5.19(0.150/4/2)
uname -s = CYGWIN_NT-5.1
uname -v = 2006-01-20 13:28
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = unknown
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /usr/lib/lapack
PATH: /opt/rtems/i386-rtems-gcc/bin
## Core tests. ##
configure:1337: checking for gmake
configure:1366: result: no
configure:1337: checking for make
configure:1353: found /usr/bin/make
configure:1363: result: make
configure:1387: checking for RTEMS Version
configure:1389: result: 4.6.99.2
configure:1414: checking build system type
configure:1432: result: i686-pc-cygwin
configure:1440: checking host system type
configure:1454: result: i686-pc-cygwin
configure:1462: checking target system type
configure:1476: result: i386-pc-rtems
configure:1504: checking for a BSD-compatible install
configure:1559: result: /usr/bin/install -c
configure:1570: checking whether build environment is sane
configure:1613: result: yes
configure:1678: checking for gawk
configure:1694: found /usr/bin/gawk
configure:1704: result: gawk
configure:1714: checking whether make sets $(MAKE)
configure:1734: result: yes
configure:1893: checking whether to enable maintainer-specific portions of Makefiles
configure:1902: result: no
configure:2674: creating ./config.status
configure:3521: configuring in ./tools/build
configure:3633: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/build/configure' '--prefix=/opt/rtems/i386-rtems' '--
host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--targ
et=i386-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/build'
configure:3521: configuring in ./tools/cpu
configure:3633: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' '--prefix=/opt/rtems/i386-rtems' '--ho
st=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--target
configure:3636: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' failed for tools/cpu
## Cache variables. ##
ac_cv_build=i686-pc-cygwin
ac_cv_build_alias=i686-pc-cygwin
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=set
ac_cv_env_target_alias_value=i386-rtems
ac_cv_host=i686-pc-cygwin
ac_cv_host_alias=i686-pc-cygwin
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_MAKE=make
ac_cv_prog_make_make_set=yes
ac_cv_target=i386-pc-rtems
ac_cv_target_alias=i386-rtems
## Output variables. ##
ACLOCAL='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run aclocal-1.9'
AMTAR='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run tar'
AUTOCONF='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run autoconf'
AUTOHEADER='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run autoheader'
AUTOMAKE='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run automake-1.9'
AWK='gawk'
CYGPATH_W='cygpath -w'
DEFS='-DPACKAGE_NAME=\"rtems\" -DPACKAGE_TARNAME=\"rtems\" -DPACKAGE_VERSION=\"4.6.99.2\" -DPACKAGE_STRING=\"rtems\ 4.6.99.2\" -DPACKAGE_BUGREPORT=\"
rtems-bugs at rtems.com\" '
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
LIBOBJS=''
LIBS=''
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKE='make'
MAKEINFO='${SHELL} /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/missing --run makeinfo'
MULTILIB_FALSE=''
MULTILIB_TRUE='#'
PACKAGE='rtems'
PACKAGE_BUGREPORT='rtems-bugs at rtems.com'
PACKAGE_NAME='rtems'
PACKAGE_STRING='rtems 4.6.99.2'
PACKAGE_TARNAME='rtems'
PACKAGE_VERSION='4.6.99.2'
PATH_SEPARATOR=':'
PROJECT_ROOT='./$(top_builddir)'
PROJECT_TOPdir='./$(top_builddir)'
RTEMS_HAS_NETWORKING='yes'
RTEMS_HAS_POSIX_API='yes'
RTEMS_HAS_RDBG='no'
RTEMS_TOPdir='.'
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
VERSION='4.6.99.2'
ac_ct_STRIP=''
am__leading_dot='.'
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='i686-pc-cygwin'
build_SUBDIRS=' tools/build tools/cpu'
build_alias=''
build_configdirs=' tools/build tools/cpu'
build_cpu='i686'
build_os='cygwin'
build_subdir='.'
build_vendor='pc'
buildargs=''--host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-
tests' '--target=i386-rtems''
datadir='${prefix}/share'
exec_prefix='${prefix}'
host='i686-pc-cygwin'
host_SUBDIRS=''
host_alias=''
host_configdirs=''
host_cpu='i686'
host_os='cygwin'
host_subdir=''
host_vendor='pc'
hostargs=''--host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--target=i386-rtems' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enab
le-posix' '--disable-tests''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
prefix='/opt/rtems/i386-rtems'
program_transform_name='s,^,i386-rtems-,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='i386-pc-rtems'
target_SUBDIRS=' i386-rtems/c'
target_alias='i386-rtems'
target_configdirs=' c'
target_cpu='i386'
target_os='rtems'
target_subdir='i386-rtems'
target_vendor='pc'
targetargs=''--host=i386-rtems' '--build=i686-pc-cygwin' '--target=i386-rtems' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable
## confdefs.h. ##
#define PACKAGE_BUGREPORT "rtems-bugs at rtems.com"
#define PACKAGE_NAME "rtems-tools-cpu"
#define PACKAGE_STRING "rtems-tools-cpu 4.6.99.2"
#define PACKAGE_TARNAME "rtems-tools-cpu"
#define PACKAGE_VERSION "4.6.99.2"
configure: exit 1
best regards
ole at danelec.dk
* Software Manager
* danelec electronics a/s
* Blokken 44
* DK-3460 Birkeroed
* DENMARK
* Phone: +45 45821879
* Fax: +45 45821979
* Email: ole at danelec.dk
* http://www.danelec.dk
* ftp://ftp.danelec.dk
* Radio call sign: oz1jru
* If you seek luck, luck will strike you ..... 8o) *
> -----Original Message-----
> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
> Sent: 14. marts 2006 07:19
> To: Ole Hansen
> Cc: Joel Sherrill; RTEMS Users
> Subject: RE: SV: RTEMS 4.6.4 fails on Cygwin
> On Tue, 2006-03-14 at 06:41 +0100, Ole Hansen wrote:
> > Hello Joe
> > When you say environment, do you then mean what I see when I type:
> > env in the shell
> This is what Joel is referring to.
> > or do you mean the tools I use ????
> Please, show us your config.log and show us your error message.
> Ralf
> BTW: You are not only having problems with RTEMS, you are also having
> problems with your mailer (It tears threads apart) and with quoting
> mails (This renders your mails close to unreadable. cf.
> http://learn.to/quote ).
