4.6.99.2 Re: SV: RTEMS 4.6.4 fails on Cygwin
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Mar 14 12:12:55 UTC 2006
FWIW I recently built powerpc tools from source and RTEMS from the
CVS head on Cygwin. It is still likely an environment problem.
--joel
Ralf Corsepius wrote:
>On Tue, 2006-03-14 at 08:00 +0100, Ole Hansen wrote:
>>Hello Ralf
>>This is what is printed on the screen:
>>configure: configuring in ./tools/cpu
>>configure: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' '--prefix=/opt/rtems/i386-rtems' '--host=i6
>>86-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--target=i386
>>-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu'
>>checking for gmake... no
>>checking for make... make
>>checking for RTEMS Version... 4.6.99.2
>You are building RTEMS-4.6.99.2 (either RTEMS-CVS or a snapshot
>tarball), not RTEMS-4.6.4 as you've told us before!
>>configure: configuring in generic
>>configure: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/generic/configure' --prefix=/opt/rtems/i386-rtems '--
>>prefix=/opt/rtems/i386-rtems' '--host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-
>>posix' '--disable-tests' '--target=i386-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu'
>> 'build_alias=i686-pc-cygwin' 'host_alias=i686-pc-cygwin' 'target_alias=i386-rtems' --cache-file=/dev/null --srcdir=/cygdrive/c/CVSROOT/development/i
>>configure: creating ./config.status
>>config.status: creating Makefile
>>.infig.status: ...
>Cut'n'pasto or a Cygwin buffer overflow?
>>... error: cannot find input file: Makefile
>This either indicates
>* you didn't generate the configuration files correctly (Hard to guess,
>because I don't know which sources you are using)
>* you are facing a Cygwin bug (We've had this before, at this or a
>similar place - IIRC, the work around was to extend some of the
>Windows/Cygwin resources, but I don't recall which).
>* you are facing a shell bug.
>>configure: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/generic/configure' failed for generic
>>configure: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' failed for tools/cpu
>>obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems
>>$ ls
>>Here is my config.log:
>>obh at olenb2 /cygdrive/c/CVSROOT/development/ioboards/rtems/build-pc386-i386-rtems
>>$ cat config.log
>>This file contains any messages produced by compilers while
>>running configure, to aid debugging if configure makes a mistake.
>> which was
>>generated by GNU Autoconf 2.59. Invocation command line was
>> $ /cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/configure --target=i386-rtems --enable-rtemsbsp=pc386 --prefix=/opt/rtems/i386-rtems --d
>>isable-cxx --disable-itron --enable-posix --disable-tests
>>## Platform. ##
>>hostname = olenb2
>>uname -m = i686
>>uname -r = 1.5.19(0.150/4/2)
>>uname -s = CYGWIN_NT-5.1
>>uname -v = 2006-01-20 13:28
>>/usr/bin/uname -p = unknown
>>/bin/uname -X = unknown
>>/bin/arch = unknown
>>/usr/bin/arch -k = unknown
>>/usr/convex/getsysinfo = unknown
>>hostinfo = unknown
>>/bin/machine = unknown
>>/usr/bin/oslevel = unknown
>>/bin/universe = unknown
>>PATH: /usr/local/bin
>>PATH: /usr/bin
>>PATH: /bin
>>PATH: /usr/X11R6/bin
>>PATH: /usr/lib/lapack
>>PATH: /opt/rtems/i386-rtems-gcc/bin
>This PATH probably is incorrect.
>Where on $PATH is i386-rtems-gcc?
>Please run
>which i386-rtems-gcc
>and
>which gcc
>Where on $PATH is automake?
>which automake
>>## Core tests. ##
>>configure:1337: checking for gmake
>>configure:1366: result: no
>>configure:1337: checking for make
>>configure:1353: found /usr/bin/make
>>configure:1363: result: make
>>configure:1387: checking for RTEMS Version
>>configure:1389: result: 4.6.99.2
>>configure:1414: checking build system type
>>configure:1432: result: i686-pc-cygwin
>>configure:1440: checking host system type
>>configure:1454: result: i686-pc-cygwin
>>configure:1462: checking target system type
>>configure:1476: result: i386-pc-rtems
>>configure:1504: checking for a BSD-compatible install
>>configure:1559: result: /usr/bin/install -c
>>configure:1570: checking whether build environment is sane
>>configure:1613: result: yes
>>configure:1678: checking for gawk
>>configure:1694: found /usr/bin/gawk
>>configure:1704: result: gawk
>>configure:1714: checking whether make sets $(MAKE)
>>configure:1734: result: yes
>>configure:1893: checking whether to enable maintainer-specific portions of Makefiles
>>configure:1902: result: no
>>configure:2674: creating ./config.status
>>configure:3521: configuring in ./tools/build
>>configure:3633: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/build/configure' '--prefix=/opt/rtems/i386-rtems' '--
>>host=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--targ
>>et=i386-rtems' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/build'
>>configure:3521: configuring in ./tools/cpu
>>configure:3633: running /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' '--prefix=/opt/rtems/i386-rtems' '--ho
>>st=i686-pc-cygwin' '--build=i686-pc-cygwin' '--enable-rtemsbsp=pc386' '--disable-cxx' '--disable-itron' '--enable-posix' '--disable-tests' '--target
>>configure:3636: error: /bin/sh '/cygdrive/c/CVSROOT/development/ioboards/rtems/rtems-src/tools/cpu/configure' failed for tools/cpu
>What does
>/bin/sh --version
>say?
>Ralf
