Problem to save file on the hard disk! What I have to set to do it ?
    Thomas Doerfler (nt)
    Thomas.Doerfler at imd-systems.de
    Tue Mar 14 19:23:28 UTC 2006
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Matteo,
one other question:
After reading the partition table, the "fileio" sample will print a
result code. Can you tell me what is printed there as a result?
wkr,
Thomas.
Matteo schrieb:
> I have two FAT partition;
> - one is hda2, is for " windows xp " and is FAT32(is about 20GB),
> - another one is hda1, is a free memory FAT16(is about 2.8 GB).
> I can mount hda2 and hda1 and  write a file on them without problem.
> What's the problem about your opinion?
> May be I have to set some special options in my Grub(my linux bootloader) when I
> have to launch the example?
> Really thanks in advance.
> Matteo
> Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
>>Matteo,
>>it really looks like a difficult case to me :-((
>>What is confusing me: Your FAT partition has a size of about 20GB. This
>>is MUCH to big for a FAT16 partition, so I would guess, that a program
>>that is asked to format the disk should complain about this.
>>In your last posts, you have sent me information about what is written
>>in the partition table for partition hda1. For clarity, I have to ask
>>again: did you also:
>>- format the partition
>>- mount it under linux to some mount point
>>- write files to it
>>and everything without problems?
>>wkr,
>>Thomas.
>>Matteo schrieb:
>>>Thomas,
>>>Yes I can access to windows from linux.
>>>I created hda1 using gparted formatting hda1 as FAT16.
>>>Infact if I use gparted, like you can see, it says that is FAT16, but if I
>>use
>>>only "cfdisk" says that is only linux.
>>>I try to see my memory using also qtparted and It says me that hda1 is
>>FAT16
>>>partition.
>>>I don't know why "cfdisk -l /dev/hda" don't shows that hda1 is FAT16.
>>>But both gparted both qtparted program shows that hda1 is a FAT16 !
>>>Have you some idea about my problem ?
>>>Really Thanks in advance
>>>Matteo
>>>Matteo,
>>>I am a bit confused, your listing shows, that /dev/hda1 is a Linux ext3
>>>partition, but you write that gparted shows it as FAT16. But /dev/hda2
>>>looks fine in the partition table. can you access the filesystem on
>>>/dev/hda2 from linux?
>>>Thomas.
>>>Matteo schrieb:
>>>>Ok this is the result of the command "fdisk -l /dev/hda"
>>>>Disk /dev/hda: 40.0 GB, 40007761920 bytes
>>>>255 heads, 63 sectors/track, 4864 cylinders
>>>>Units = cilindri of 16065 * 512 = 8225280 bytes
>>>>Dispositivo Boot      Start         End      Blocks   Id  System
>>>>/dev/hda1            2678        3014     2706952+  83  Linux
>>>>/dev/hda2               1        2677    21502971    c  W95 FAT32 (LBA)
>>>>/dev/hda3            3015        4784    14217525   83  Linux
>>>>/dev/hda4            4785        4864      642600    5  Esteso
>>>>/dev/hda5            4785        4864      642568+  82  Linux swap /
>>>Solaris
>>>>looking with gparted I have the result that, hda1 is "FAT16", hda2 is
>>>"FAT32",
>>>>hda3 is "ext3", hda4 is "exetended", hda5 is "linux swap".
>>>>I created hda1 with FAT16 thinking to resolve the problem, but from the
>>>fileio
>>>>example I have always the same error,
>>>>" fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file or
>>>>directory " but now hda1 is FAT16 so it could be right for RTEMS, but it
>>>isn't.
>>>>Why ?
>>>>Can you help me ?
>>>>Thanks advanced
>>>>MAtteo
>>IMD Ingenieurbuero fuer Microcomputertechnik
>>Thomas Doerfler           Herbststrasse 8
>>D-82178 Puchheim          Germany
>>email:    Thomas.Doerfler at imd-systems.de
>>PGP public key available at:
>>     http://www.imd-systems.de/pgpkey_en.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.5 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFEFxgwwHyg4bDtfjQRAvZ9AJ9WJ/gAMrsN4gAL+xFPTU6ORILk0wCfcnQ9
y1s9iHINDbrRi7YUSY3by1w=
=8f/L
-----END PGP SIGNATURE-----
