Problem to save file on the hard disk! What I have to set to do it ?
    Chris Johns
    chrisj at rtems.org
    Thu Mar 16 23:32:56 UTC 2006
Matteo wrote:
> Sorry I didn't think it was so different.
> So I search in the mailing list and I don't find something about the gcc 4.x and
> problem with the samples.
  http://www.rtems.org/ml/rtems-users/2006/march/msg00027.html
> So I try to increase, like you say, the minimun stack size in this way ;
> #define CONFIGURE_EXTRA_TASK_STACKS         (100 * RTEMS_MINIMUM_STACK_SIZE)
> but it's the same problem, may be I have to set another one costant ?
Add:
#define CONFIGURE_INIT_TASK_STACK_SIZE  (100 * RTEMS_MINIMUM_STACK_SIZE)
to the system.h file in the example and try again.
Regards
