Problem to save file on the hard disk! What I have to set to do it ?
Angelo Fraietta
newsgroups at smartcontroller.com.au
Fri Mar 17 02:39:55 UTC 2006
I am only using RTEMS version 4.6.4 - will that be a problem? Is it
using the same compiler?
Matteo wrote:
> Hi Angelo,
> Ok thank you the link is
> ftp://ftp.rtems.com/pub/rtems/4.6.99.2/examples-4.6.99.2.tar.bz2
> and the example is "fileio".
> Thanks
> Scrive Angelo Fraietta <newsgroups at smartcontroller.com.au>:
>>Could you please send me a link to the latest fileio example. I have
>>been using the dos driver for a while with no problem. I can test it
>>here on a machine
>>Thomas Doerfler (nt) wrote:
>>>Matteo,
>>>I am VERY confused now, because I thought you would be running the
>>>fileio example already for some days.
>>>There was an issue that most samples did not start at all because the
>>>new GCC 4.x needs a bigger minimum stack size, so this may be the
>>>problem with the original fileio example. (see previous postings on this
>>>mailing list).
>>>So this is a totally different issue, I think. Can you try to fix it and
>>> try the fileio example again with the fix?
>>>wkr,
>>>Thomas.
>>>Matteo schrieb:
>>>>Hi Thomas,
>>>>Ok I sent you the hda2_info.gz but with another one my email
>>matte0pos at yahoo.it(
>>>>because with this I have a limit for the message).
>>>>Today I try to launch the full example fileio example and I see that it
>>doesn't
>>>>work !
>>>>Every time I have try to launch my file example in which I put the three
>>>>function of the fileio example;
>>>>to read the partion table - fileio_part_table_initialize ()
>>>>to mount the partions - fileio_fsmount ()
>>>>to write the file - fileio_write_file ();
>>>>And every time I have the error when I try to mount the partition.
>>>>Today I launch the full example of fileio and I look that nothing appened!
>>Only
>>>>the first message:
>>>>" Initialized console on port CONSOLE " and stop. I look it today because
>>I
>>>>always worked on my very simple example..
>>>>How it's possible ? Surely the error is here yet .
>>>>Have you some idea? I forget to say you that I'm working on a notebook but
>>the
>>>>hard disk are IDE, I try to launch the example on a normal computer and I
>>have
>>>>the same result.
>>>>Really thanks.
>>>>Matteo
>>>>Scrive Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
>>>>>Matteo,
>>>>>I got no idea, what might go wrong on your machine. According to your
>>>>>answer, the partiton table is read in correctly. Can you do the
>>>>>following for me:
>>>>>under linux, can you log in as root and perform the following commands:
>>>>># dd if=/dev/hda of=hda_partition_table bs=512 count=1
>>>>># dd if=/dev/hda2 of=hda2_info bs=512 count=22000
>>>>># gzip <hda2_info >hda2_info.gz
>>>>>This will read the partition table and the start of hda2 (including the
>>>>>boot sector, the FAT and some file contents of that partition) from your
>>>>>disk. If you send me these two files (as private mail) I can try to
>>>>>analyze the info stored there.
>>>>>Please note, with the above commands, some file content of your harddisk
>>>>>will be sent to me aswell, so please do it only if you do not have
>>>>>private or confidential information on this partiton.
>>>>>wkr,
>>>>>Thomas.
>>>>>Matteo wrote:
>>>>>>Hi Thomas,
>>>>>>The result after reading the partition table is "RESULT = 0"
>>>>>>I create the /mnt/hda1 too, with linux I can write and mount without
>>>>>problem on
>>>>>>hda1(FAT16). So why with RTEMS I can't do it ?
>>>>>>Have you some idea ?
>>>>>>Thanks
>>>>>>Scrive "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>:
>>>>Matteo,
>>>>one other question:
>>>>After reading the partition table, the "fileio" sample will print a
>>>>result code. Can you tell me what is printed there as a result?
>>>>wkr,
>>>>Thomas.
>>>>Matteo schrieb:
>>>>>I have two FAT partition;
>>>>>- one is hda2, is for " windows xp " and is FAT32(is about 20GB),
>>>>>- another one is hda1, is a free memory FAT16(is about 2.8 GB).
>>>>>I can mount hda2 and hda1 and write a file on them without problem.
>>>>>What's the problem about your opinion?
>>>>>May be I have to set some special options in my Grub(my linux bootloader)
>>>>when I
>>>>>have to launch the example?
>>>>>Really thanks in advance.
>>>>>Matteo
>>>>>>Matteo,
>>>>>>it really looks like a difficult case to me :-((
>>>>>>What is confusing me: Your FAT partition has a size of about 20GB. This
>>>>>>is MUCH to big for a FAT16 partition, so I would guess, that a program
>>>>>>that is asked to format the disk should complain about this.
>>>>>>In your last posts, you have sent me information about what is written
>>>>>>in the partition table for partition hda1. For clarity, I have to ask
>>>>>>again: did you also:
>>>>>>- format the partition
>>>>>>- mount it under linux to some mount point
>>>>>>- write files to it
>>>>>>and everything without problems?
>>>>>>wkr,
>>>>>>Thomas.
>>>>>>Matteo schrieb:
>>>>>>>Thomas,
>>>>>>>Yes I can access to windows from linux.
>>>>>>>I created hda1 using gparted formatting hda1 as FAT16.
>>>>>>>Infact if I use gparted, like you can see, it says that is FAT16, but
>>>>>>if
>>>>I
>>>>>>use
>>>>>>>only "cfdisk" says that is only linux.
>>>>>>>I try to see my memory using also qtparted and It says me that hda1 is
>>>>>>FAT16
>>>>>>>partition.
>>>>>>>I don't know why "cfdisk -l /dev/hda" don't shows that hda1 is FAT16.
>>>>>>>But both gparted both qtparted program shows that hda1 is a FAT16 !
>>>>>>>Have you some idea about my problem ?
>>>>>>>Really Thanks in advance
>>>>>>>Matteo
>>>>>>>Matteo,
>>>>>>>I am a bit confused, your listing shows, that /dev/hda1 is a Linux ext3
>>>>>>>partition, but you write that gparted shows it as FAT16. But /dev/hda2
>>>>>>>looks fine in the partition table. can you access the filesystem on
>>>>>>>/dev/hda2 from linux?
>>>>>>>Thomas.
>>>>>>>Matteo schrieb:
>>>>>>>>Ok this is the result of the command "fdisk -l /dev/hda"
>>>>>>>>Disk /dev/hda: 40.0 GB, 40007761920 bytes
>>>>>>>>255 heads, 63 sectors/track, 4864 cylinders
>>>>>>>>Units = cilindri of 16065 * 512 = 8225280 bytes
>>>>>>>>Dispositivo Boot Start End Blocks Id System
>>>>>>>>/dev/hda1 2678 3014 2706952+ 83 Linux
>>>>>>>>/dev/hda2 1 2677 21502971 c W95 FAT32
>>>>>>(LBA)
>>>>>>>>/dev/hda3 3015 4784 14217525 83 Linux
>>>>>>>>/dev/hda4 4785 4864 642600 5 Esteso
>>>>>>>>/dev/hda5 4785 4864 642568+ 82 Linux swap /
>>>>>>>Solaris
>>>>>>>>looking with gparted I have the result that, hda1 is "FAT16", hda2 is
>>>>>>>"FAT32",
>>>>>>>>hda3 is "ext3", hda4 is "exetended", hda5 is "linux swap".
>>>>>>>>I created hda1 with FAT16 thinking to resolve the problem, but from
>>>>>>the
>>>>>>>fileio
>>>>>>>>example I have always the same error,
>>>>>>>>" fsmount: mounting of "/dev/hda1" to "/mnt/hda1" failed: No such file
>>>>>>or
>>>>>>>>directory " but now hda1 is FAT16 so it could be right for RTEMS, but
>>>>>>it
>>>>>>>isn't.
>>>>>>>>Why ?
>>>>>>>>Can you help me ?
>>>>>>>>Thanks advanced
>>>>>>>>MAtteo
>>>>>>IMD Ingenieurbuero fuer Microcomputertechnik
>>>>>>Thomas Doerfler Herbststrasse 8
>>>>>>D-82178 Puchheim Germany
>>>>>>email: Thomas.Doerfler at imd-systems.de
>>>>>>PGP public key available at:
>>>>>> http://www.imd-systems.de/pgpkey_en.html
>>Angelo Fraietta
>>PO Box 859
>>Hamilton NSW 2303
>>Home Page
>>http://www.smartcontroller.com.au/~angelo/
>>There are those who seek knowledge for the sake of knowledge - that is
>>CURIOSITY
>>There are those who seek knowledge to be known by others - that is VANITY
>>There are those who seek knowledge in order to serve - that is LOVE
>> Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
CURIOSITY
