Problem to save file on the hard disk! What I have to set to do it ?
    Matteo
    matteo.posterli at studenti.unipr.it
    Fri Mar 17 14:42:26 UTC 2006
First of all I do " export PATH="$PATH:/usr/local/rtems/rtems4.7/bin" "
I applied the path for binutils-2.16.1 and newlib-1.13.0
I configure binutils like following ;
../binutils-2.16.1/configure --target=i386-rtems4.7
--prefix=/usr/local/rtems/rtems4.7
and I compiled it ; make -w all install
I configure gcc like following ;
../gcc-4.0.2/configure --target=i386-rtems4.7 --prefix=/usr/local/rtems/rtems4.7
--with-gnu-as --with-gnu-ld --with-newlib --verbose --with-system-zlib
--disable-nls --enable-version-specific-runtime-libs --enable-threads=rtems
--enable-languages=c,c++
The directory tree is;
/usr/local/rtems/source/tool/binutils-2.16.1
/usr/local/rtems/source/tool/newlib-1.13.0
/usr/local/rtems/source/tool/gcc-4.0.2
and I have succesfully compile binutils but I have problem with gcc, like you
can see below :), I think to have follow all the istruction, may be I forget to
set something ?
Thanks in advantage
Matteo
Scrive Karel Gardas <kgardas at objectsecurity.com>:
> Matteo,
> what configure parameters have you used for configuring your gcc? Also
> have you linked newlib's `newlib' directory to gcc's source code directory
> as recommended?
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.4/share/rtems/html/started/started00041.html
> Karel
> On Fri, 17 Mar 2006, Matteo wrote:
> > Hi Joel,
> > I'm reistalling RTEMS with the following ;
> > binutils-2.16.1
> > newlib-1.13.0
> > gcc-4.0.2
> > rtems from the cvs
> > but I have the problem compiling gcc-4.0.2, like this ;
> > -DL_fixunsdfsi -c ../../gcc-4.0.2/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
> > In file included from
> /usr/local/rtems/source/tools/b-gcc/gcc/include/syslimits.h:7,
> >                 from
> /usr/local/rtems/source/tools/b-gcc/gcc/include/limits.h:11,
> >                 from ../../gcc-4.0.2/gcc/libgcc2.c:1487:
> > /usr/local/rtems/source/tools/b-gcc/gcc/include/limits.h:122:61: error: no
> > include path in which to search for limits.h
> > make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
> > make[2]: Leaving directory `/usr/local/rtems/source/tools/b-gcc/gcc'
> > make[1]: *** [stmp-multilib] Error 2
> > make[1]: Leaving directory `/usr/local/rtems/source/tools/b-gcc/gcc'
> > make: *** [all-gcc] Error 2
> > make: Leaving directory `/usr/local/rtems/source/tools/b-gcc'
> > root at matteo:/usr/local/rtems/source/tools/b-gcc#
> > So I don't know why ?
> > I have add the following path before start all the installation ;
> > But it said me that can't find the limit.h, but I don't know wich other
> path I
> > have to add!
> > Can you help me ?
> > Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
> >> Matteo wrote:
> >>> Infact I installed this version of rtems because with that suggested
> from
> >> the
> >>> "download helper" I had some problem.
> >>> So, I decid to reinstall all rtems with the version suggest from the
> >> download
> >>> helper(so I'm sure that all the samples works!);
> >>> gcc-3.2.3
> >>> newlib-1.11.0
> >>> binutils-2.13.2.1
> >>> rtems-4.6.5
> >>> So I applied the patch for gcc and newlib, a export the
> >>> I configure binutils in this way;
> >> You downloaded a 4.6 release and toolset and are configuring it for
> >> rtems 4.7.  RTEMS tools have evolved so you can have toolsets for
> >> multiple verions of RTEMS installed concurrently.  They follow
> >> this history:
> >> Version         Prefix           Naming
> >>   4.5         /opt/rtems        CPU-rtems-TOOL
> >>   4.6        /opt/rtems-4.6   CPU-rtems-TOOL
> >>   4.7        /opt/rtems-4.7   CPU-rtems4.7-TOOL
> >> For each RTEMS release series, there is a matched C library version
> >> an recommended GCC version.  Sometimes depending on the compiler,
> >> you can change the GCC version a little but the C library version is
> >> mated and should be used.
> >> You are mismatching things.
> >>> and I launch "make -w all install", but I have this error ;
> >>> Wmissing-prototypes -g -O2 -c ../../binutils-2.13.2.1/gas/app.c
> >>> In file included from ./targ-cpu.h:1,
> >>>                 from ../../binutils-2.13.2.1/gas/config/obj-elf.h:42,
> >>>                 from ./obj-format.h:1,
> >>>                 from ../../binutils-2.13.2.1/gas/config/te-generic.h:19,
> >>>                 from ./targ-env.h:1,
> >>>                 from ../../binutils-2.13.2.1/gas/as.h:614,
> >>>                 from ../../binutils-2.13.2.1/gas/app.c:30:
> >>> ../../binutils-2.13.2.1/gas/config/tc-i386.h:530: error: array type has
> >>> incomplete element type
> >>> make[3]: *** [app.o] Error 1
> >>> make[3]: Leaving directory
> `/usr/local/rtems/source/tools/b-binutils/gas'
> >>> make[2]: *** [all-recursive] Error 1
> >>> make[1]: *** [all-recursive-am] Error 2
> >>> make: *** [all-gas] Error 2
> >>> make: Leaving directory `/usr/local/rtems/source/tools/b-binutils'
> >>> root at matteo:/usr/local/rtems/source/tools/b-binutils#
> >>> That was the same error that convinced me to try another version of
> rtems.
> >>> So have you some idea about to resolve this configuration problem ?
> >>> Thanks in advance
> >>> MAtteo
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
