Problem to save file on the hard disk! What I have to set to do it ?
    Matteo
    matteo.posterli at studenti.unipr.it
    Fri Mar 17 15:14:13 UTC 2006
Thanks, you get reason, I forgot to do it
Matteo
Scrive Karel Gardas <kgardas at objectsecurity.com>:
> On Fri, 17 Mar 2006, Matteo wrote:
> > First of all I do " export PATH="$PATH:/usr/local/rtems/rtems4.7/bin" "
> > I applied the path for binutils-2.16.1 and newlib-1.13.0
> > I configure binutils like following ;
> > ../binutils-2.16.1/configure --target=i386-rtems4.7
> > --prefix=/usr/local/rtems/rtems4.7
> > and I compiled it ; make -w all install
> > I configure gcc like following ;
> > ../gcc-4.0.2/configure --target=i386-rtems4.7
> > --with-gnu-as --with-gnu-ld --with-newlib --verbose --with-system-zlib
> > --disable-nls --enable-version-specific-runtime-libs
> --enable-threads=rtems
> > --enable-languages=c,c++
> > The directory tree is;
> > /usr/local/rtems/source/tool/binutils-2.16.1
> > /usr/local/rtems/source/tool/newlib-1.13.0
> > /usr/local/rtems/source/tool/gcc-4.0.2
> > and I have succesfully compile binutils but I have problem with gcc, like
> you
> > can see below :), I think to have follow all the istruction, may be I
> forget to
> > set something ?
> and have you done this:
> cd /usr/local/rtems/source/tool/gcc-4.0.2
> ln -s /usr/local/rtems/source/tool/newlib-1.13.0/newlib .
> before you configure gcc?
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
