Problem to save file on the hard disk! What I have to set to do it ?
Matteo matteo.posterli at studenti.unipr.it
Sun Mar 19 17:41:07 UTC 2006
Hi Joel,
following your suggestion I follow the
http://www.rtems.com/wiki/index.php/RTEMSAda guide, but I have a problem.
I download from the cvs rtems and I have only this in the directory;
acinclude.m4 aclocal automake bootstrap bpskit c
So, like the guide suggests, I launch ./bootstrap but I have this error  ;
bash: ./bootstrap. /bin/sh^M: bad interpreter: no such file or directory
So I try the launch the other executable file ./acinclude.m4 and I have this
error;
root at matteo:/usr/local/rtems/source/tools/rtems-4.7# ./acinclude.m4
: command not founde 5:
./acinclude.m4: line 6: syntax error near unexpected token
`2.59' '/acinclude.m4: line 6: `AC_PREREQ(2.59)
What means ?
I have installed autoconf-2.59 and automake-1.9.6, with newlib-1.13.0, binutils-
2.16.1, gcc-4.0.2
Somebody can help me ?
Thanks in advance
Matteo
Scrive Joel Sherrill <joel.sherrill at oarcorp.com>:
> Matteo wrote:
> >Hi Joel,
> >I'm reistalling RTEMS with the following ;
> >binutils-2.16.1
> >newlib-1.13.0
> >gcc-4.0.2
> >rtems from the cvs
> >but I have the problem compiling gcc-4.0.2, like this ;
> > -DL_fixunsdfsi -c ../../gcc-4.0.2/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
> >In file included from
> /usr/local/rtems/source/tools/b-gcc/gcc/include/syslimits.h:7,
> >                 from
> /usr/local/rtems/source/tools/b-gcc/gcc/include/limits.h:11,
> >                 from ../../gcc-4.0.2/gcc/libgcc2.c:1487:
> >/usr/local/rtems/source/tools/b-gcc/gcc/include/limits.h:122:61: error: no
> >include path in which to search for limits.h
> >make[2]: *** [libgcc/./_fixunsdfsi.o] Error 1
> >make[2]: Leaving directory `/usr/local/rtems/source/tools/b-gcc/gcc'
> >make[1]: *** [stmp-multilib] Error 2
> >make[1]: Leaving directory `/usr/local/rtems/source/tools/b-gcc/gcc'
> >make: *** [all-gcc] Error 2
> >make: Leaving directory `/usr/local/rtems/source/tools/b-gcc'
> >root at matteo:/usr/local/rtems/source/tools/b-gcc#
> >So I don't know why ?
> >I have add the following path before start all the installation ;
> >export PATH="$PATH:/usr/local/rtems/rtems4.7/bin"
> >But it said me that can't find the limit.h, but I don't know wich other path
> I
> >have to add!
> >Can you help me ?
> http://www.rtems.com/wiki/index.php/RTEMSAda is Laurent Guerby's notes
> on building
> a C/Ada toolset. When you see --enable-languages your options are c,
> c++, and ada.
> Those are pretty easy to follow.
> >>Matteo wrote:
> >>>Infact I installed this version of rtems because with that suggested from
> >>the
> >>>"download helper" I had some problem.
> >>>So, I decid to reinstall all rtems with the version suggest from the
> >>download
> >>>helper(so I'm sure that all the samples works!);
> >>>gcc-3.2.3
> >>>newlib-1.11.0
> >>>binutils-2.13.2.1
> >>>rtems-4.6.5
> >>>So I applied the patch for gcc and newlib, a export the
> >>>I configure binutils in this way;
> >>>../binutils-2.16.1/configure --target=i386-rtems4.7
> >>>--prefix=/usr/local/rtems/rtems4.7
> >>You downloaded a 4.6 release and toolset and are configuring it for
> >>rtems 4.7.  RTEMS tools have evolved so you can have toolsets for
> >>multiple verions of RTEMS installed concurrently.  They follow
> >>this history:
> >>Version         Prefix           Naming
> >>  4.5         /opt/rtems        CPU-rtems-TOOL
> >>  4.6        /opt/rtems-4.6   CPU-rtems-TOOL
> >>  4.7        /opt/rtems-4.7   CPU-rtems4.7-TOOL
> >>For each RTEMS release series, there is a matched C library version
> >>an recommended GCC version.  Sometimes depending on the compiler,
> >>you can change the GCC version a little but the C library version is
> >>mated and should be used.
> >>You are mismatching things.
> >>>and I launch "make -w all install", but I have this error ;
> >>>Wmissing-prototypes -g -O2 -c ../../binutils-2.13.2.1/gas/app.c
> >>>In file included from ./targ-cpu.h:1,
> >>>                from ../../binutils-2.13.2.1/gas/config/obj-elf.h:42,
> >>>                from ./obj-format.h:1,
> >>>                from ../../binutils-2.13.2.1/gas/config/te-generic.h:19,
> >>>                from ./targ-env.h:1,
> >>>                from ../../binutils-2.13.2.1/gas/as.h:614,
> >>>                from ../../binutils-2.13.2.1/gas/app.c:30:
> >>>../../binutils-2.13.2.1/gas/config/tc-i386.h:530: error: array type has
> >>>incomplete element type
> >>>make[3]: *** [app.o] Error 1
> >>>make[3]: Leaving directory `/usr/local/rtems/source/tools/b-binutils/gas'
> >>>make[2]: *** [all-recursive] Error 1
> >>>make[2]: Leaving directory `/usr/local/rtems/source/tools/b-binutils/gas'
> >>>make[1]: *** [all-recursive-am] Error 2
> >>>make[1]: Leaving directory `/usr/local/rtems/source/tools/b-binutils/gas'
> >>>make: *** [all-gas] Error 2
> >>>make: Leaving directory `/usr/local/rtems/source/tools/b-binutils'
> >>>root at matteo:/usr/local/rtems/source/tools/b-binutils#
> >>>That was the same error that convinced me to try another version of
> rtems.
> >>>So have you some idea about to resolve this configuration problem ?
> >>>Thanks in advance
> >>>MAtteo
