Rtems 4.6.99.3 - cdefs.h
Steven Johnson
sjohnson at sakuraindustries.com
Tue May 2 20:36:37 UTC 2006
Further to the following email,
it turns out that the only header file installed by rtems that refers to
cdefs.h is rtems_bsdnet_internal.h
It #include's both 'rtems/cdefs.h' and 'sys/cdefs.h'
Why?
I cant see any definitions in rtems/cdefs.h that arent made in
sys/cdefs.h. Shouldn't the #include to 'rtems/cdefs.h' be changed to
'sys/cdefs.h' and then the second (and lower) #include of 'sys/cdefs.h'
be removed?
If this is done, i don't find any other references to 'rtems/cdefs.h',
so couldn't it be safely removed?
Attached is a patch which does just this.
Steven Johnson
Steven Johnson wrote:
>Hi,
>Im trying to get my application to build now using 4.6.99.3 and im
>getting the following conflict:
>include/rtems/cdefs.h:49:1:error:"__END_DECLS" redefined
><blah>
>include/sys/cdefs.h:44:1:error:this is the location of the previous
>definition
>Both are part of the RTEMS install, and are not coming from my standard
>library.
>Apart from some typographical differences, the nature and contents of
>each file is identical, so why are there 2 files with the same
>declarations? Isnt one redundant?
>How do I prevent this?
>Steven
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20060503/cd44b597/attachment.bin>
