Need Help building libcsupport on Solaris 10/sun4u
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Tue May 16 02:53:26 UTC 2006
Looks like a version issue related to your local C compiler.  What
version are you using?
Regards,
Greg
jonathan.kalbfeld at gmail.com writes:
 > Hello,
 > I have my build tools in /export/rtems-4.6 (not opt) and I already
 > edited make/custom/Solaris-posix.cfg to add -D__EXTENSIONS__
 > What other things do I have to do make it finish?  I'm investigating
 > the feasibility of using RTEMS instead of VxWorks!
 > Here's where it is hanging up:
 > Making all in libcsupport
 > gmake[4]: Entering directory
 > `/home/jonathan/rtems/4.6-work/c/posix/exec/libcsupport'
 > gcc --pipe -DHAVE_CONFIG_H   -isystem ../../../.././posix/lib/include
 > -Isrc     -Dsolaris2 -D__EXTENSIONS__  -O2 -g -Wall  -o
 > o-optimize/termios.o -c
 > .../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/termios.c
 > .../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/termios.c:
 > In function `rtems_termios_ioctl':
 > .../../../../../rtems-4.6.6/c/src/../../cpukit/libcsupport/src/termios.c:628:
 > error: `u_int32_t' undeclared (first use in this function)
