icmp echo disable (or dont answer pings)
Steven Johnson
sjohnson at sakuraindustries.com
Wed May 31 05:41:53 UTC 2006
Chris Johns wrote:
> Joel Sherrill wrote:
>> Comments please. This does seem like a reasonable application feature.
> I would like to see the Wiki updated to document this feature as it is
> not standard.
Will Do.
> Extending the stack this way could result in this feature being lost
> if (or when) the stack is upgraded. I see it is a simple patch which
> provides a specific solution to a specific problem, but have to wonder
> what FreeBSD does to handle this normally. Does it use some sort of
> firewall rules ? If it does could this approach have been used ?
I don't know how FreeBSD handles this, as you say it doesnt have a
network stack option as standard. I looked in their code base to see if
there was, so i could use their sysctl name. Linux does, with the
sysopt "icmp_echo_ignore_all". Linux has different sysopt names from
the FreeBSD stack, so i tried to use a name which was closer to the
current name's in use in the FreeBSD stack. Im not sure how a Firewall
rule could do it, because its tied into the network protocol stack, and
I would have thought the firewall would need to set the option in the stack.
Another way to resolve any feature lost on a future import would be to
submit the patch to the FreeBSD people for inclusion into their code
base. As I don't have the FreeBSD code base, and I know next to nothing
about FreeBSD, except for the few man pages on their sysctl's i read,
that's not something I can do.
>>> case ICMP_ECHO:
>>> - if (!icmpbmcastecho
>>> - && (m->m_flags & (M_MCAST | M_BCAST)) != 0
>>> - && IN_MULTICAST(ntohl(ip->ip_dst.s_addr))) {
>>> + if (!icmpallecho + || (!icmpbmcastecho
>>> + && (m->m_flags & (M_MCAST | M_BCAST)) != 0
>>> + && IN_MULTICAST(ntohl(ip->ip_dst.s_addr)))) {
>>> icmpstat.icps_bmcastecho++;
>>> break;
> This code does not update the icps_allecho counter. Should it ?
Um, yes it should. Bugger. Attached is a revised patch to fix that.
Thanks,
Steven J
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20060531/92375f8f/attachment.bin>
