sparc erc32 FPU confusion
Aleix Conchillo Flaqué aconchillo at ieec.fcr.es
Wed May 31 09:15:49 UTC 2006
On 31 May 2006, at 10:51, Jiri Gaisler wrote:
> Tasks that are not marked as FPU tasks could therefore trap
> unless they are compiled with lower optimization effort,
> OR with -msoft-float.
> an FPU is present and enabled. The kernel can (and must)
> therefore always be compiled with -msoft-float to avoid
> spurious FPU instructions due to gcc optimizations. If
> your application uses the FPU, these parts should be
> compiled without -msoft-float. If you share code between
> FPU tasks and non-FPU tasks, you must decrease the
> optimization level to avoid unexpected FPU instructions
> as explained above.
So, this means that the kernel can still be compiled with -O4 (like
before) as it is forcing to not use the FPU with the -msoft-float?
Do you know from which version of gcc this is the behaviour?
aleix
