Context Switch Problem
Joel Sherrill
joel.sherrill at oarcorp.com
Fri May 12 15:04:07 UTC 2006
Samuel Bitton wrote:
>I don't believe that's the problem though as the software actually breaks during context switch, i.e. I don't come out of the _Context_Switch, and as far as I can tell the enabling of the interrupts is not done by _Context_Switch but by _ISR_Enable which happens just after.
ISRs are enabled as a side-effect of the popf in the following code
sequence. :)
restore:
pushl REG_EFLAGS(eax) /* push eflags */
popf /* restore eflags */
movl REG_ESP(eax),esp /* restore stack pointer */
movl REG_EBP(eax),ebp /* restore base pointer */
movl REG_EBX(eax),ebx /* restore ebx */
movl REG_ESI(eax),esi /* restore source register */
movl REG_EDI(eax),edi /* restore destination
register */
ret
-joel
>Regards
>Sam
> -----Original Message-----
>From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>Sent: 12 May 2006 16:21
>To: Chris Johns
>Cc: Samuel Bitton; rtems-users at rtems.com
>Subject: Re: Context Switch Problem
>>>Hi
>>>I'm currently working on a new RTEMS BSP for a custom made board
>>>based around the i386ex processor.
>>>The software currently breaks towards the end of RTEMS
>>>initialisation, at the point where it is doing the first context
>>>switch (_Context_Switch called at the end of
>>>_Thread_Start_multitasking).
>>>My application only has one small init task which toggles a line
>>>indefinitely.
>>>Any idea what could be going wrong.
>>>I'm using RTEMS 4.6.4.
>>Have you look over this page:
>> http://www.rtems.org/wiki/index.php/DebuggingHints
>>It has some reasons a BSP can fail.
>And the most likely reason is included there -- an interrupt is pending
>and you are taking
>an exception. The first context switch enables CPU interrupts and any
>device not in a
>quiescent state will slap you here. :)
>--joel
>>Regards
>>Chris
