build RTEMS TIc4x
Ralf Corsepius ralf.corsepius at rtems.org
Mon Nov 6 02:58:50 UTC 2006
On Sun, 2006-11-05 at 18:58 -0600, Joel Sherrill wrote:
> liu danil wrote:
> > Hello,anybody.
> > My recent project has a TI c3x DSP board, and I want to use RTEMS on it.
> > But I tried for two weeks and couldn't find a right RTEMS and Tools version
> > combination.
> > I tried rtems-4.7-tic4x-rtems4.7-***.i386.rpm files in the
> > ftp.rtems.com/rtems/linux/4.7/redhat/7.3/i386 directory, but they didn't
> > work.
> First the tic4x was removed from the 4.7 release branch so it is an
> accident to have the tools out there for 4.7. You should be trying it
> with 4.8 tools and use the tic4x port from CVS.
Sorry, you're in error.
The tic4x had NOT removed from rtems-4.7, nor should using rtems-4.8
toolchains instead of rtems-4.7-toolchains make any difference, because
both tic4x-toolchains are more or less identical.
Ralf
