log2 defined as macro
    Johnny Willemsen
    jwillemsen at remedy.nl
    Tue Nov  7 08:50:07 UTC 2006
Hi,
I found that rtems defines the log2 method in math.h as macro. This causes
problems when the application also has a method called log2, is it possible
that in future versions of rtems log2 is a real function, so that
application code can still use log2 as method also.
Regards,
Johnny Willemsen
Remedy IT
Postbus 101
2650 AC  Berkel en Rodenrijs
The Netherlands
www.theaceorb.nl / www.remedy.nl
