Building RTEMS for a host?
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Tue Nov 7 18:02:07 UTC 2006
Hello,
you are right, simulating a target on a host is quite efficent in many
cases. There are several ways to do this:
You can build RTEMS for one of the simulator targets. AFAIK the
following are supported:
PSIM (PowerPC Architecture), ERC32 (Sparc Architecture) and QEMU (which
at least simulates an i386). These targets are simulated inside a GDB
session. Other simulators might be usable aswell.
Another way to simulate RTEMS would be to build for a "posix" target,
with this target, your RTEMS software system will be compiled and linked
to a program executable that can be run on your host system (e.g Linux
system on a i386 machine). But AFAIK this method is no longer so heavily
used due to the benefits you get from the simulator approach.
wkr/mfg,
Thomas Dörfler.
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
Stefan.Pusl at comneon.com schrieb:
> Hello,
> I'm a newcomer regarding RTEMS and I investigate, if RTEMS can be used as real-time operating system on a host for testing activities. In the documentation of RTEMS I always read about building RTEMS for a specific target. Is there a way to use RTEMS on a host, because the first testing activities for an application a more effective on a host?
> Best regards
> Pusl
> Stefan Pusl
> COMNEON GmbH & Co.  OHG
> An Infineon Technologies Company
> Rosenheimer Str. 116
> D-81669 München Germany
> Phone: +49 (0)89 234 27713
> Fax:     +49 (0)89 234 27840
> Email: stefan.pusl at comneon.com
> rtems-users mailing list
> rtems-users at rtems.com
