Xilinx IP core drivers for RTEMS- Keith Robertson still around?
D. Peter Siddons
siddons at bnl.gov
Wed Nov 8 15:51:04 UTC 2006
I'm interested in bringing up RTEMS on the PPC in a Memec XC4FX12 board.
Has anyone done that? I'd appreciate getting hold of anything close to
try and modify. Did anything get deposited anywhere after this email
thread? I couldn't see anything on CVS.
Thanks,
Pete.
Robert S. Grimes wrote:
> Consider yourself kicked - with all due respect, of course!
> Ed Sutter wrote:
>> Great.
>> I have code examples for hooking up RTEMS to uMon, plus I've hooked
>> up TFS to RTEMS FS also. It hasn't been heavily tested, but if you
>> think you can use it lemme know and I'll try to find it.
>> Maybe that will *finally* kick me in the butt enough to put this
>> info on the RTEMS Wiki also.
>> Ed
>>> Hi Ed,
>>> Oh, yeah - you did - works great, too!
>>> -Bob
>>> Ed Sutter wrote:
>>>> Bob,
>>>> I gave you what I have for the ML403/micromonitor stuff right?
>>>> If you need help with that, lemme know.
>>>> Ed Sutter
>>>>> Hi Greg,
>>>>> Please, less formality - Bob is fine by me!
>>>>> Sounds like I'll be following you, I guess! I had originally (as
>>>>> in earlier today) thought I'd finish my MicroMonitor work first,
>>>>> but perhaps I should move RTEMS up first. It doesn't really matter
>>>>> too much for me, and hopefully I'll be able to contribute more -
>>>>> given your schedule.
>>>>> Do you have the TEMAC working yet? Or are you using one of the
>>>>> "soft" IP cores? What serial port core are you using?
>>>>> Take care,
>>>>> gregory.menke at gsfc.nasa.gov wrote:
>>>>>> Thanks Robert!
>>>>>> Exactly what I needed. Over the next few days I will be working the
>>>>>> patches in and comparing to the firmware as its been specified in our
>>>>>> board- its quite similar to an ML403. We do have flexibility wrt the
>>>>>> Virtex firmware so reconfigs there will not be an issue. I think the
>>>>>> goal will be to create a proper bsp to support our board. The
>>>>>> initial
>>>>>> tests will be RTEMS running our flight software, taking data in
>>>>>> over a
>>>>>> serial port and transmitting out of ethernet.
>>>>>> I'd be happy to share the RTEMS portions of the work & collaborate
>>>>>> wherever its feasable. We have to be running & stable by the end of
>>>>>> August so development is going to be brisk over the next couple
>>>>>> weeks.
>>>>>> Regards,
>>>>>> Greg
>>>>>> Robert S. Grimes writes:
>>>>>> > Hi Greg,
>>>>>> > > I'm in the same boat as you. Keith has sent me his diffs,
>>>>>> which I > include here. Note that they are against a little
>>>>>> older version > (V4.6.5) of RTEMS, and should work on a suitably
>>>>>> configured Xilinx ml403 > board. You'll have to make sure your
>>>>>> V4 configuration is compatible > with his stuff, or change one
>>>>>> side or another...
