Installation problem for target "(none)"
Stefan.Pusl at comneon.com Stefan.Pusl at comneon.com
Wed Nov 29 10:26:21 UTC 2006
Hello,
I'm looking desperately for an answer for my problem. I use Cygwin on a
Windows PC and I tried to read the file README.configure carefully. In
this I found, that the following target and associated BSPs are
supported:
Target: (none)      BSP: posix
Thus I tried the command:
../rtems-4.6.6/configure --disable-rtems-inlines --enable-rtemsbsp=posix
--prefix=$HOME --target=
And I also tried the command:
--prefix=$HOME
Both commands worked fine, but the succeeding command
Make all
Stopped by an error.
I don't know, what I did wrong.
Best regards
Stefan
