Installation problem for target "(none)"
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed Nov 29 10:49:24 UTC 2006
Stefan,
I think your problem is, that the "posix" BSP only runs on systems, that
have enough posix compliants built in. Unfortunately cygwin is not
supported for this BSP, see:
rtems/c/src/lib/libbsp/unix/posix/README
If you want to try out RTEMS in a simulated environemt (also under
cygwin), you may try out the psim BSP (a Powerpc simulated inside the
gdb debugger) or "QEMU". See:
http://www.rtems.com/wiki/index.php/Emulator
wkr,
Thomas.
Stefan.Pusl at comneon.com schrieb:
> Hello,
> I'm looking desperately for an answer for my problem. I use Cygwin on a
> Windows PC and I tried to read the file README.configure carefully. In
> this I found, that the following target and associated BSPs are
> supported:
> Target: (none)      BSP: posix
> Thus I tried the command:
> ../rtems-4.6.6/configure --disable-rtems-inlines --enable-rtemsbsp=posix
> --prefix=$HOME --target=
> And I also tried the command:
> --prefix=$HOME
> Both commands worked fine, but the succeeding command
> Make all
> Stopped by an error.
> I don't know, what I did wrong.
> Best regards
> Stefan
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
