Installation problem for target "(none)"
Ralf Corsepius ralf.corsepius at rtems.org
Wed Nov 29 11:11:48 UTC 2006
On Wed, 2006-11-29 at 11:49 +0100, Thomas Doerfler wrote:
> Stefan,
> I think your problem is, that the "posix" BSP only runs on systems, that
> have enough posix compliants built in. Unfortunately cygwin is not
> supported for this BSP, see:
That's news to me.
A linux->cygwin cross compiler definitely is able to build it. It also
should at least be buildable natively under cygwin.
However, I don't know if it runs under cygwin, because I don't run
cygwin.
Stefan, could you provide more details about the problems you are
seeing?
> rtems/c/src/lib/libbsp/unix/posix/README
Note the date: 1995/12/19
This is really outdated.
Ralf
