[rtems] Has RTEMS 4.7 Released ?
Wed Nov 29 12:27:09 UTC 2006
paopaoerzhang at msik.com.cn wrote:
> I see the last release version is 4.6.6.
> and Can check out 4.7 from the CVS
> so ask a question, 4.7 Released ?
I would like to reply but it might contain confidential information.
You sent this question and this horrible paragraph to a public mailing
list which is
distributed to 100s of subscribers, archived, indexed by multiple search
engines
and cached by at least Google.
AGAIN ... do not sent email to this mailing list with this type of
paragraph.
The answer is -- it has been branched but no formal releases cut.
--joel
> Best wishes,
> paopaoer
> *****CONFIDENTIAL INFORMATION*****
> This email is intended only for the use of the person or entity to
> whom it is addressed and contains information that may be subject to
> and/or may be restricted from disclosure by contract or applicable
> law. If you are not the intended recipient of this email, be advised
> that any disclosure, copy, distribution or use of the contents of this
> message is strictly prohibited. If you are not the intended recipient
> of this email, please notify the sender that you have received this in
> error by replying to this message. Then, please delete it from your
> system. Thank you.
> rtems-users mailing list
> rtems-users at rtems.com
