Installation problem for target "(none)"
Stefan.Pusl at comneon.com
Thu Nov 30 15:13:48 UTC 2006
Hello,
I started from the scratch and tried now the following configure-command
under Cygwin:
../rtems-4.6.6/configure --enable-rtemsbsp=posix
And I received the same error as with the additional option
'--disable-rtems-inlines':
Making preinstall in dosfs
make[7]: Entering directory
`/cygdrive/h/GNU/try_rtems/build/c/posix/exec/libfs/src/dosfs'
Makefile:518: *** multiple target patterns. Stop.
make[7]: Leaving directory
make[6]: *** [preinstall-recursive] Error 1
make[6]: Leaving directory
`/cygdrive/h/GNU/try_rtems/build/c/posix/exec/libfs/src'
make[5]: *** [preinstall-recursive] Error 1
make[5]: Leaving directory
`/cygdrive/h/GNU/try_rtems/build/c/posix/exec/libfs'
make[4]: *** [preinstall-recursive] Error 1
make[4]: Leaving directory
`/cygdrive/h/GNU/try_rtems/build/c/posix/exec'
make[3]: *** [preinstall-recursive] Error 1
make[3]: Leaving directory `/cygdrive/h/GNU/try_rtems/build/c/posix'
make[2]: *** [posix] Error 1
make[2]: Leaving directory `/cygdrive/h/GNU/try_rtems/build/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/cygdrive/h/GNU/try_rtems/build/c'
make: *** [all-recursive] Error 1
The makefile from the path
'/cygdrive/h/GNU/try_rtems/build/c/posix/exec/libfs/src/dosfs'
, which generates the error, is given below:
<<Makefile>>
Does anyone now, what I missed under Cygwin?
Best regards
Stefan
Desc: Makefile
URL: <http://lists.rtems.org/pipermail/users/attachments/20061130/33c08e0a/attachment.obj>
