GoAhead WebServer in RTEMS
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Nov 1 12:28:10 UTC 2006
Ian Caddy wrote:
> Hi All,
> Joel Sherrill wrote:
>> Chris Johns wrote:
>>> Eric Valette wrote:
>>>> It is indeed. It wasn't at the time of submission (about 5 years ago
>>>> already). If I had to select one now, I would choose the one by the
>>>> guy
>>>> that did GoHead dev and that is still compatible with goahed : appweb
>>>> <www.appweb.org>.
>>> Do you mean http://www.appwebserver.org/ ?
>> The license for that is pure GPL so isn't good for RTEMS. If the
>> GoAhead webserver is
>> indeed obsolete, then we need to identify another candidate and port it.
> I was just looking at the AppWeb site and the way I read the license
> section:
> "If your software is 100% GPL *or is licensed under an Open Source
> License that is OSI approved* and acceptable to Mbedthis Software,
> you may use Mbedthis products and embed them in your applications or
> devices. You do not need any other agreement or license -- the GPL is
> all you need."
> The Open Source License includes the LGPL which I thought was
> acceptable to us?
> It might be worth contacting the site to see if RTEMS would be an
> acceptable platform for Mbedthis. Maybe an RTEMS official? ;-)
I didn't contact them but my reading is that it would be OK to use it
with RTEMS and any example application since they
are all open source/GPL. But your application probably isn't GPL and it
would be statically linked with RTEMS and their
web server -- thus requiring a commercial license.
Option 1: Completely GPL statically linked image
Option 2: Proprietary application, commercial license
This is just another example of the license hassles we want to avoid
with RTEMS.
> regards,
> Ian Caddy
