Spurious IRQ7
    Angelo Fraietta
    newsgroups at smartcontroller.com.au
    Tue Nov  7 03:10:06 UTC 2006
Grigori Khmyrov wrote:
> I have problem with extra interrupts at i686 industrial computer.
> It never happened before with old VIA C3 400 MHz (100x4.0) board.
> But I have an extra interrupts with new one VIA C3 667 MHz (133x5.0).
> We have a hardware which produces signal every 5 ms. We use the signal
> as IRQ7.
> Very rear I see an extra call of interrupt handler. Spurious IRQ7
> happens. I'm sure
> that our hardware is not producing that signal. Is it any suggestion
> what can be
> wrong. Can it be 8259A Interrupt Controller or RTEMS?
> I'm using RTEMS 4.6.2 with i486 BSP.
> Any suggestion how to fix or catch a problem appreciated.
What does the signal look like with a CRO?
You might be getting reflections back that are causing reflective spikes
(this happened to me and appeared as extra pulses) so check your impedances
Dr Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/~angelo/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
