build RTEMS TIc4x
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Nov 13 15:49:28 UTC 2006
Ralf Corsepius wrote:
>>> On Thu, 2006-11-09 at 15:54 +0800, liu danil wrote:
>> This must be what I was remembering as the problem that prevented it
>> from being buildable.
>>>> /opt/rtems/tic4x-rtems/c3xsim/lib/librtemscpu.a(libscore_a-threadhandler.o):threadhandler.:(.text+0x27):
>>>> undefined reference to `__init'
>>>> /opt/rtems/tic4x-rtems/c3xsim/lib/librtemsbsp.a(startup.rel):bootcard.c:(.const+0x23):
>>>> undefined reference to `__fini'
>>>> How can I do to solve these problems?
>>> You don't seem to have the rtems-patches to newlib and gcc applied.
>> That explains the __init/__fini problem but the console one may indicate
>> a missing file in the Makefile.am
>> or something worse.
> Which console error are you referring to?
http://www.rtems.org/ml/rtems-users/2006/november/msg00045.html
/opt/rtems/tic4x-rtems/c3xsim/lib/librtemsbsp.a(console.rel):simio.c:(.text+0x1f6):
undefined reference to `_Console_Port_Count'
It looks like the c4xsim BSP is linking against shared/console.c instead of the BSP specific
one. See c4xsim/Makefile.am and doublecheck me.
> Ralf
> PS: This mailing lists's headers are still broken.
I will ping Jeff.
--joel
