Rtems Networking
Luca Germano
lucagermano at hotmail.com
Thu Nov 16 08:49:06 UTC 2006
Hi
this is the result of the nm
/opt/rtems-4.6/sparc-rtems/leon3/lib$ nm librtemscpu.a |grep timeout
nm: condmp.o: no symbols
eventtimeout.o:
nm: itronapi.o: no symbols
U timeout
U timeout
00000094 d last_adjusted_timeout.0
00000090 d rtq_timeout
U timeout
nm: mutexmp.o: no symbols
nm: res_stubs.o: no symbols
nm: rtclock.o: no symbols
nm: semaphoremp.o: no symbols
00000000 d timeout
00000008 d tottimeout
00000000 d timeout
00000000 d timeout
ratemontimeout.o:
00000a00 T timeout
nm: strlcat.o: no symbols
nm: strlcpy.o: no symbols
nm: threadget.o: no symbols
nm: threadidlebody.o: no symbols
nm: time.o: no symbols
threadqtimeout.o:
U timeout
I try to opend the rtems source file but I didn't find duplicated symbols.
Look at warning message I find timeout into file rtems_glue.c. At line 516
and 519 there are two assignment to unsigner32 variable named timeout.
unsigned32 timeout;
While at line 516 there is
timeout = c->c_time;
where c_time is a structure of type timeval
at line 519 there is
timeout = RTEMS_NO_TIMEOUT;
where RTEMS_NO_TIMEOUT is a value equal to 0.
Could be the assignement of line 516, a structure assigned to a unsigned
int, the problem?
Thanks
Luca
>From: Joel Sherrill <joel.sherrill at oarcorp.com>
>To: Luca Germano <lucagermano at hotmail.com>
>CC: rtems-users at rtems.org
>Subject: Re: Rtems Networking
>Date: Wed, 15 Nov 2006 16:57:29 -0600
>Luca Germano wrote:
>>Hi
>>I try to use network under RTEMS. I look the RTEMS netdemos examples.
>>Compling my application I have the following warning message:
>>/opt/rtems-4.6/lib/gcc-lib/sparc-rtems/3.2.3/../../../../sparc-rtems/bin/ld:
>>Warning: size of symbol `timeout' changed from 4 to 244 in
>>/opt/rtems-4.6/sparc-rtems/leon3/lib/librtemscpu.a(rtems_glue.o)
>>Warning: type of symbol `timeout' changed from 1 to 2 in
>>Someone have had this warning message or can explain me how to solve?
>This usually indicates that the symbol is defined in two different object
>files.
>Can you poke around with nm and grep on the libraries and see if it is
>duplicately defined?
>timeout is such a common word, it wouldn't surprise me to find it in two
>places.
>--joel
>>Thanks for the help
>>Luca
>>_________________________________________________________________
>>Scopri la perfetta integrazione tra MSN Hotmail e Windows Live Messenger!
>>http://join.msn.com/hotmail/features-std#6
>>rtems-users mailing list
>>rtems-users at rtems.com
>>http://rtems.rtems.org/mailman/listinfo/rtems-users
Aggiungi il modulo Amici al tuo Spaces con un click!
http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=it-it
