Fwd: Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Tue Nov 21 15:21:30 UTC 2006
Ralf Corsepius wrote:
>>> On Tue, 2006-11-21 at 13:38 +0100, Thomas Doerfler wrote:
>>>> I found a good discussion about GCC and strict aliasing here:
>>>> http://www.cellperformance.com/mike_acton/2006/06/understanding_strict_aliasing.html
>>>> Maybe it would help to modify the definition of Chain_Ctronol to
>>>> something like:
>>>> typedef union {
>>>>   struct {
>>>>     struct Chain_Node_struct head;
>>>>     void *fill_loc1;
>>>>   } head_node;
>>>>   struct {
>>>>     void *fill_loc1;
>>>>     struct Chain_Node_struct tail;
>>>>   } tail_node;
>>>> } Chain_Control;
>>>> The names are NOT good, and surely all chain.c/chain.inl functions would
>>>> have to be adapted but this might be a mechanical search/replace procedure.
>>>> Any comments to a change like this?
>> Using a union like this would probably remove a lot of casts and could
>> make the code easier to read.
> It's "'em casts" which are the origin of this evil!
:)  I have attached a patch which (if my grep worked) which should make
a big
dent in this.
+ In malloc.c, we keep a chain of pending memory to free and I added
an intermediate variable between the free'ed address being queued.
+ I don't know how to deal with the macros/routines _Chain_Head and
_Chain_Tail
in chain.inl.
+ Chain_Initialize in chain.c has a cast of an address when building the
chain initially
and I don't know how to deal with that.
Suggestions on the cases above to improve the attached patch and see if
it is enough
to address Peer's problem.
>> I would want to be careful about the names.  And the changes do extend
>> a bit out of the chain code.  There are a few places which explicitly do
>> casts to (Chain_Node *) which could be cleaned up.
> Remove these casts and eliminate the "punned warnings" without using
> explict casts. In 90% of all cases all you'll probably need to solve the
> issue is a temporary pointer.
> Ralf
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061121/88c7374f/attachment-0001.bin>
