Fwd: Problem report: Struct aliasing problem causes Thread_Ready_Chain corruption in 4.6.99.3
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Nov 21 16:01:46 UTC 2006
Ralf Corsepius wrote:
> On Tue, 2006-11-21 at 16:38 +0100, Thomas Doerfler wrote:
>> Therefore your patch in malloc.c is IMHO identical to the previous
>> explicit cast.
> Please prove Joel's patch to be broken.
I did that because that type of code fixed previous punning problems. It
seems to tell gcc that we knew what we were doing. If you look at a lot
of the changes between 4.6 and 4.7 you will see more than a few changes
following this pattern.
I am more concerned about the _Chain_Head and _Chain_Tail routines.
I don't see how to clean them up without the union. And I believe (but
can't prove) that they are the root of gcc's confusion.
--joel
> Ralf
