[rtems] Has RTEMS 4.7 Released ?
paopaoerzhang at msik.com.cn
Wed Nov 29 05:59:04 UTC 2006
I see the last release version is 4.6.6.
and Can check out 4.7 from the CVS
so ask a question, 4.7 Released ?
Best wishes,
paopaoer
*****CONFIDENTIAL INFORMATION*****
This email is intended only for the use of the person or entity to whom it is addressed and contains information that may be subject to and/or may be restricted from disclosure by contract or applicable law. If you are not the intended recipient of this email, be advised that any disclosure, copy, distribution or use of the contents of this message is strictly prohibited. If you are not the intended recipient of this email, please notify the sender that you have received this in error by replying to this message. Then, please delete it from your system. Thank you.
URL: <http://lists.rtems.org/pipermail/users/attachments/20061129/0edbc2d0/attachment-0001.html>
