Installation problem for target "(none)"
    Thomas Doerfler
    Thomas.Doerfler at embedded-brains.de
    Wed Nov 29 12:35:28 UTC 2006
stefan, Ralf,
sory for the wrong information in my previous mail.
I have just built the posix BSP rtems-4.6.99.2 under cygwin.
I configured it as follows:
../rtems-4.6.99.2/configure --enable-rtemsbsp=posix
It built fine and the sample applications work aswell.
So, what I learned today: the posix BSP can be build and run in (my)
cygwin environment.
Stefan, compared to my configure line, you have used the switch
"-disable-rtems-inlines". Maybe you should give it a try with inlines
allowed. And If you get another error, please post the configure command
line and the error output you received.
wkr,
Thomas.
Ralf Corsepius schrieb:
> On Wed, 2006-11-29 at 11:49 +0100, Thomas Doerfler wrote:
>> Stefan,
>> I think your problem is, that the "posix" BSP only runs on systems, that
>> have enough posix compliants built in. Unfortunately cygwin is not
>> supported for this BSP, see:
> That's news to me.
> A linux->cygwin cross compiler definitely is able to build it. It also
> should at least be buildable natively under cygwin.
> However, I don't know if it runs under cygwin, because I don't run
> cygwin.
> Stefan, could you provide more details about the problems you are
> seeing?
>> rtems/c/src/lib/libbsp/unix/posix/README
> Note the date: 1995/12/19
> This is really outdated.
> Ralf
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
