[RTEMS-Users] [Fwd: i960 simulation problem]
Pam Renton prenton at pv-labs.com
Fri Oct 6 13:39:48 UTC 2006
I am looking at options for existing systems, which use the i960. So
thanks very much. That is important information.
-----Original Message-----
[mailto:rtems-users-bounces at rtems.org] On Behalf Of Joel Sherrill
Sent: October 5, 2006 9:19 AM
To: RTEMS Users Mailing List
Subject: [RTEMS-Users] [Fwd: i960 simulation problem]
I think this is the only message of substance
which came in during the transfer and probably
did not get propagated.
You don't mention a version but the i960sim BSP
was never completely functional.  Even when it
worked enough to run hello world, it did not
implement all the i960 instructions generated by
gcc and never had any support for a clock tick.
Also gcc for the i960 is reported to be broken
for all gcc versions >= 3.0.  That is ultimately
why it was dropped from gcc.
Combine that with running on cygwin and who really
knows how broken everything is.
Why again do you want to be on an i960?
