[RTEMS-Users] MinGW Tools for Windows
Sun Oct 8 08:46:08 UTC 2006
Smith, Gene SEA wrote:
> Is the procedure documented for building the "MinGW Tools for Windows"
> as described here
> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows
This documents how to use the installers that are on the RTEMS ftp server.
> I am looking for a reproducible way to make gnu arm tools that run under
> windows w/o cygwin.
The scripts to build the tools is found here:
http://www.rtems.org/cgi-bin/viewcvs.cgi/rtems/contrib/mingw/
It uses the crossrpms scripts. The installers are built on a Fedora Core
5 box. I have not had time to add something on these scripts in the Wiki.
Regards
