RTEMS with C++
Tue Oct 10 12:09:35 UTC 2006
Fabrício de Novaes Kucinskis wrote:
> I'd like to know if someone here uses C++ with RTEMS.
I do and so do a number of the people I consult too.
> What are the advantages? I see just disadvantages, such as the obvious
> overhead.
The general arguments for and against C++ should apply when used with
RTEMS. Decide on using C++ based on your application rather than a fit
of C++ to RTEMS.
You can write efficient code in C++ with the same overhead as C. I am
working on a class for a high data rate HDLC controller all written in C++.
> I don't see a good use for objects instantiated inside only one task (maybe
> the encapsulation of the code?), and since the communication between objects
> in different tasks should be done through the RTEMS managers, I think
> there's no reason to use C++ and OO in a RTEMS application. But I'd like to
> be convinced that C++ in RTEMS is something good.
I tend to look at classes and threads in the opposite way. I write a
class for a specific purpose and if it needs a thread I embed one in
that class where a member function is the thread body. At an upper level
of the design I use an instance of that class or more than one instance
and I do not have to consider the threads involved.
> One more question: does the "librtems++" switch link the OO wrappers to the
> managers?
The wrapper classes are all separate and should only reference the
managers they use so if you do not use a class it should not pull in
manager.
Regards
