Bug in termios
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Thu Oct 19 14:28:14 UTC 2006
jennifer at oarcorp.com wrote:
> I have a system with 12 serial port.  The driver is configured to be
> interrupt driven with one character arrival per interrupt.  Furthermore,
> I am using 1 task which is set up to poll the serial ports in raw mode at
> a 10 ms rate and distribute any data that has arrived.  To do this I have
> set VMIN and VTIME to 0.  The problem occurs on high bandwidth devices
> (after they have ran a while), when the device is turned off.  Turning off
> the device results in the system locking up for several seconds then
> recovering.  Analysis has shown that the read command is locking the
> system during this time.  It appears to me that the problem is happening
> is that inside of termios.c in the fillBufferQueue routine.  While the
> device is running there are always characters available so rawInBuff.Head
> and rawInBuffTail are never equal.   Then ccount is always >=  c_cc[VMIN]
> which results in wait being set to 0 and the semaphore never being
> decremented even thought it being incremented approximately 20 times
> during the 10 ms application task poll rate.  When the serial device is
> turned off and the characters are emptied out of the termios buffer, this
> results in a spinlock of obtaining the rawInBufSemaphore several hundred
> thousand times.
I looked at the code and believe this semaphore was intended to be used
as a counting
semaphore. I think each increment is for an interrupt occurrence -- not
for a single
character. It is simply not decremented via obtain unless a task is
willing to block.
In Jennifer's case, this is very rare so the count is VERY high when she
finally
doesn't have any data and has to way.
I suggested that this probably needs to be a simple binary semaphore but
she had
already tried that and it broke something else. She is now trying to do
a flush on
this semaphore just before checking the buffer counts. Technically, this
is a
condition mutex and we should be able to get away with that. You don't
care about
it until there is no data and then you want to block on it until just
the next interrupt.
Eric.. do you see what is going on? I know it has been years but you
originally
wrote this code.
--joel
> I have tried several things to balance the semaphore count,  but can’t
> seem to get something that doesn’t break some other aspect of termios.
> Any suggestions would be appreciated
> Thanks
> Jennifer
> rtems-users mailing list
> rtems-users at rtems.com
