Bug in termios
jennifer at oarcorp.com
Mon Oct 23 14:22:25 UTC 2006
I am unable to create a bug report, but I have attached the patch that
resolves the termios read problem.
Jennifer
> Joel Sherrill schrieb:
>> jennifer at oarcorp.com wrote:
>>>Changing to a simple binary semaphore works. What I had checked before
>>> was
>>>changing it to a binary semaphore, not a simple binary. We are going to
>>>run over the weekend, but this appears to have solved the problem.
>> Jennifer, If the test passes all weekend, we need to get a patch merged.
> i have detected the same problem VMIN = VTIME = 0. termios docu says it is
> *never* blocking but blocks.
> is there a PR filed and a patch available? thanks
> Schöne Grüße aus Reutlingen
> Wolfram Wadepohl
> Forschung & Entwicklung
> E&K AUTOMATION
> Indumat GmbH & Co. KG
> Siemensstraße 3
> 72766 Reutlingen
> Deutschland
> Tel. +49 7121 514-289
> Fax +49 7121 514-299
> eMail W.Wadepohl at indumat.de
> Wolfram.Wadepohl at ek-automation.com
> W.Wadepohl at ieee.org
> WWW http://www.indumat.de
> http://www.ek-automation.com
> Bitte senden Sie mir keine Word- oder PowerPoint- (tm Microsoft) Anhänge.
> Senden Sie mir einfachen Text, HTML oder PDF.
> Siehe http://www.gnu.org/philosophy/no-word-attachments.de.html
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20061023/ddad1295/attachment.txt>
