Loading RTEMS on an MCP750
Thu Oct 26 18:57:25 UTC 2006
Amalaye Oyake wrote:
> On the MCP750 I traditionally tip in (via serial link using the UNIX tip
> command) and I can change the board configuration ... After consultation I
> found out that I was staring at the VxWorks at the bootrom. Can I use the
> VxWorks bootrom to load RTEMs?
I believe one of the RTEMS users has managed to do this but it wouldn't
be me. :)
> If not, I think all need is to move a jumper to get back to PPCBug.
The instructions are simpler and known if you do this.
If you are familiar with VxWorks monitor, then you might want to
consider Till
Straumann's CEXP.
--joel
> Regards,
> * Amalaye Oyake                                    *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work   818.653.4748 cell            *||
> * Jet Propulsion Laboratory, Pasadena  CA 91109   */||\
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Wednesday, October 25, 2006 2:30 PM
> To: Amalaye Oyake
> Cc: rtems-users at rtems.com
> Subject: Re: Loading RTEMS on an MCP750
>> Hello,
>> I use a Motorola MCP 750 board. It was not entirely clear on how to
>> load the OS onto the board. I presume there is some sort of bootloader
>> utility.
> Does it have the Motorola PPCBug monitor?  The instructions in
> c/src/lib/libbsp/powerpc/motorola_shared/README.MVME2300
> should be fairly close.
> But I would hope that one of the nice people out there with an MCP750
> (Greg.. hint, hint..) can provide
> more specific instructions.
> --joel
>> Thanks,
>> * Amalaye Oyake                                    *
>> rtems-users mailing list
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
