GoAhead WebServer in RTEMS
Steven Johnson
sjohnson at sakuraindustries.com
Fri Oct 27 13:35:50 UTC 2006
Hello
We have just started using the GoAhead Webserver bundled with RTEMS.
I did dome looking into the server once we started using it, to see what
the licence is, etc.
I came away a bit disturbed from this.
The product seems to be orphaned. The licence requires any
modifications made to be submitted back to the copyright holder, which
would be GoAhead. But there have been no changes to the latest release
(2.1.8), since November 2003. That's a long time.
There are a number of "community" fixes to 2.1.8, and also a number of
security advisories relating to the server code. One of those is fixed
in the RTEMS code base, the other does not appear to be.
I thought if I am going to have a product with a web server in it, I
want it to be reliable so, I have upgraded all files necessary and used
by RTEMS to 2.1.8 status. I did not want any lurking bugs that have
already been "officially" fixed causing me problems.
That is the first patch attached to this email. It also contains the
"official" change log between 2.1.4 and 2.1.8, so you can see the
fixes/changes that have been made.
I also went through the "community" bug fixes and security advisories
and applied all relevant fixes. Things I think may be of interest to
RTEMS, in particular is the WebServer will not run on 64 bit hardware.
The attached 2.1.8-to-2.1.8-2 patch will make it function properly on 64
bit hardware, as well as a number of other fixes. See the NOTES file
for a full list of fixes.
I have tested to see if these break the server. They do not, at least
as far as our application uses it. I think it would be worthwhile
having the latest, most bug fixed code for this available in RTEMS.
I also had some concern about the "We must put the web server logo on
our first page", because as bundled there was no logo. There was also
no documentation, so it was difficult to work out how to get it
working. I downloaded the official documentation, included with the
2.1.8 official archive. It includes the logo's and also API
documentation. I have extracted that from the official archive. It is
about a 466K tgz file. I think it would be worthwhile if this was
Included with the official RTEMS distribution. At the very least, the
Logo's should be, so that one can easily comply with the licence. I am
happy to post this to the list, or put it somewhere appropriate if it is
desired to be included with RTEMS. The reason I say this, is it would
be bad if GoAhead stop their official distributing of the WebServer and
then new (or existing) users of RTEMS who wanted to use the server would
not be able to access the documentation. That's also why I think it
should be updated to the latest code available, because GoAhead are
never going to have an "official" version which supports RTEMS.
On another topic, did my gethostbyname_r patch make it to the list? I
am not sure if it did or not.
Steven Johnson
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061028/b2705dc5/attachment.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061028/b2705dc5/attachment-0001.bin>
