Bug in termios
Eric Norum
norume at aps.anl.gov
Thu Oct 19 14:25:58 UTC 2006
Why is the rawInBuf.Semaphore a counting semaphore? Should it not
be a binary semaphore?
On Oct 19, 2006, at 6:48 AM, jennifer at oarcorp.com wrote:
> I have a system with 12 serial port. The driver is configured to be
> interrupt driven with one character arrival per interrupt.
> Furthermore,
> I am using 1 task which is set up to poll the serial ports in raw
> mode at
> a 10 ms rate and distribute any data that has arrived. To do this
> I have
> set VMIN and VTIME to 0. The problem occurs on high bandwidth devices
> (after they have ran a while), when the device is turned off.
> Turning off
> the device results in the system locking up for several seconds then
> recovering. Analysis has shown that the read command is locking the
> system during this time. It appears to me that the problem is
> happening
> is that inside of termios.c in the fillBufferQueue routine. While the
> device is running there are always characters available so
> rawInBuff.Head
> and rawInBuffTail are never equal. Then ccount is always >= c_cc
> [VMIN]
> which results in wait being set to 0 and the semaphore never being
> decremented even thought it being incremented approximately 20 times
> during the 10 ms application task poll rate. When the serial
> device is
> turned off and the characters are emptied out of the termios
> buffer, this
> results in a spinlock of obtaining the rawInBufSemaphore several
> hundred
> thousand times.
> I have tried several things to balance the semaphore count, but can’t
> seem to get something that doesn’t break some other aspect of termios.
> Any suggestions would be appreciated
> Thanks
> Jennifer
Eric Norum <norume at aps.anl.gov>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
URL: <http://lists.rtems.org/pipermail/users/attachments/20061019/3d5ad48b/attachment-0001.html>
