RES: RTEMS with C++
    Fabrício de Novaes Kucinskis
    fabricio at dea.inpe.br
    Thu Oct 19 17:56:26 UTC 2006
Hi Chris,
> I tend to look at classes and threads in the opposite way. I write a
> class for a specific purpose and if it needs a thread I embed one in
> that class where a member function is the thread body.
And how do you do this? Do you pass a method of an object as the entry point
for a task?
I tried this:
	rtems_task_start(id, MyObj.Method, 0);
Where 'Method' is defined in the class definition as:
	rtems_task Method(rtems_task_argument);
But it didn't work. The compiler argues that there's "no matches converting
function 'Method' to type 'rtems_task'".
What I'm doing wrong?
Thanks in advance,
Fabrício.
