RES: Remote Debugging w/Eclipse
Fabricio de Novaes Kucinskis fabricio at dea.inpe.br
Tue Oct 31 19:29:21 UTC 2006
Kevin,
You can use the Zylin CDT plugin (http://www.zylin.com/embeddedcdt.html). I
used it with RTEMS and an ERC32 processor. I couldn't put it to work with
the Sparc simulator (SIS), but it worked with no problems to debug RTEMS
applications in the target processor.
Hope this helps.
Fabricio.
  -----Mensagem original-----
  De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]Em
nome de Kirspel, Kevin {Engineering - Osmetech CCD}
  Enviada em: terca-feira, 31 de outubro de 2006 16:17
  Para: rtems-users at rtems.com
  Assunto: Remote Debugging w/Eclipse
  Has anyone used a pluggin for Eclipse that will work with the RTEMS remote
debugging server?
  Kevin Kirspel
  Research Engineer
  Osmetech
  kevin.kirspel at osmetech.com
  (ph)  770-510-4444 x4568
  (fax) 770-510-4445
URL: <http://lists.rtems.org/pipermail/users/attachments/20061031/2ee539b5/attachment-0001.html>
