Windows tools produce differant binary files
Mon Sep 4 14:15:17 UTC 2006
Mick Davis wrote:
> We're using the msys environment on windows to build for our coldfire
> target.  I'm finalising the upgrade to 4.6.99-3, which has produced a
> small improvement in our target's idle time.
Nice.
> I've got a problem using the rtems4.7-m68k-20060707-1.exe tools, which I
> also reproduced using the same tools, but built myself, under msys.
There is a newer release. Please check the Wiki page. It should be the
same compiler but it would be nice if you could try it.
> The problem is that the binary I'm producing isn't always the same,
> depending on the PC I use to build it.  3 older PCs using windows 2000
> produce one .srec, and 2 newer PCs running windows XP produce another.
Is it the same repeatable difference on each machine ?
> As well as just being suspicious, this is a problem for our quality
> system, since we support a number of engineers.
It should be the same on each machine.
> I was speculating that
> the level of optimisation may depend on the capabilities of the build
> machine?
We have a cross compiler so I would be surprised if this is the problem.
Until I can see the code and difference it would be hard to isolate.
If you wish we can take this off line to resolve.
> I use a -DNDEBUG=1 compilation flag to keep build system file names out
> of the output.  I've checked this by running the output .elf through the
> 'strings' program, and I don't see any file names.
This could still be a problem but you mention a different register used
which rules this out.
> I've been through the gcc manual, and none of the environment variables
> it mentions exist.  I've been adjusting the variables which are
> different between PCs, but none have an effect.
I do not understand what you mean here.
> Looking at the differences in the binaries themselves, the differences
> appear to be in the code, but harmless. For example, the register d0 is
> used instead of d1.  Either binary appears to run without a problem.
This is interesting. I would not expect to see this if everything is the
same.
> Can anyone point me to something in the build process which might
> produce these differences? Do the automake files put build information
> into the executable somewhere?
Could you please run the build with -save-temps on each machine and diff
the files ? If they are same then we have the same environment set up.
We can then look at the compiler for what is happening.
Regards
