Dynamic Libraries
Marek Prochazka Marek.Prochazka at scisys.co.uk
Tue Sep 5 16:37:53 UTC 2006
Hi Till,
thanks for your quick response. So, after I call cexpInit() and load a
module using cexpModuleLoad(), I can look for a function symbol using
cexpSymLookup(). This way I get CexpSym. Given that the symbol was a
function, is the way to call this function to consider
CexpSymRec_.value.tv as TFuncP (or TDFuncP?), cast this value to a
function pointer and call it? Or is there a cext_ function which I
missed to be used?
Many thanks,
Marek
> -----Original Message-----
> From: Till Straumann [mailto:strauman at slac.stanford.edu]
> Sent: 05 September 2006 16:25
> To: Marek Prochazka
> Cc: Chris Johns; rtems-users at rtems.com
> Subject: Re: Dynamic Libraries
> Marek Prochazka wrote:
> >Hi,
> >cexp seems quite interesting, but I do not see any guide how
> to use the
> >dynamic loader without the interpreter. I want to run my
> code and then
> >at some point use cexpModuleLoad etc. To do that I need some
> basic cexp
> >API documentation.
> Consult the header 'cexp.h'. You can call cexpModuleLoad() etc. from
> ordinary C-code.
> >Thanks,
> >Marek
> >>Check out cexp:
> >>http://www.slac.stanford.edu/comp/unix/package/rtems/src/ssrlA
> >>pps/cexp/README
> >>The code can be found here:
> >>ftp://www.rtems.org/pub/rtems/4.6.99.3/contrib/cexp
> You should always download from the cexp home page (i.e., the stanford
> site) to make sure you got the latest version. rtems.org
> usually lags a bit
> behind...
> HTH
> -- Till
> >>Regards
> >>Chris
